Slipped timing chain - '12 XKR
Old Jun 10, 2022 | 01:07 PM
RichardS's Avatar
Originally Posted by jahummer
Or perhaps some just do what’s right?
Possibly ...... but it took them some time to get around to it.
Richard
Old Jun 10, 2022 | 02:02 PM
bocatrip's Avatar
Originally Posted by RichardS
This is a good summary of the issues with some interesting observations about oil changes: Timing Chain Problems 2010-newer Jaguar Land Rover AJ V8 Engines - JE Robison Service - Bosch Car Service Specialists ? the blog
Thank you Richard. Yes, this is quite a comprehensive description of the timing chain scenario with oil change suggestions. After reading everything, my description in one word is BLEAK.
Old Jun 14, 2022 | 05:01 AM
edmundjbradbury's Avatar
Well - the car is back, it feels lovely to drive and everything feels smooth. The specialist garage have done a great job. Its been over 1 month in the garage and the final bill has been eye watering. On top of the timing chain replacement we have also had: new head cylinders, new supercharger clutch, new injectors, new coils, new spark plugs, new water pump (also headlamp washer jets, and right headlamp bulb - unrelated). - plus a whole list of replacement smaller parts/seals during the engine strip down. Some of these parts were directly related and necessary, some were things that needed doing and made sense to do given the extent of effort already gone in to exposing the engine.
The labour on top of that was done a 20% discount but still added up to a huge cost - all in, best part of 50% of the value of the car. I am trying to make myself feel better by telling myself that I have now at least got a very well serviced and refreshed engine, and the most expensive thing that could really go wrong with this car has happened, been fixed and shouldn't happen again.
My lesson to all XKR drivers is that if you have even the slightest hint of a rattle at idle then replace it straight away. Mine really wasn't bad at all, I had just put the noise down to it being an XKR rather than XK (which i have driven before) and thought the slightly noisy idle was just the supercharger belt. Painfully expensive experience.
Old Jun 14, 2022 | 07:59 AM
MarkyUK's Avatar
As a matter of interest when did they bring in the wider chain on the 5;?
Was it 2012 or earlier and did it result in lower reported slippage?
Old Jun 14, 2022 | 02:57 PM
bocatrip's Avatar
Aren't both the 5.0 XKR and XK equally affected with the timing chain issue?
Old Jun 14, 2022 | 04:06 PM
RichardS's Avatar
Yes, but I don't think Edmund is suggesting that they are not.
Richard
Old Jun 15, 2022 | 05:50 AM
Barry Leftwich's Avatar
I posted on here a month ago about my very sad Jag (5.0L S/C 70k) - my saga has continued to worsen. Whilst driving about a month ago the engine suddenly when into limited performance mode. I pulled over it was extremely unhappy - car rocking side to side, rough idle and then cutting out.
Long story short - the first garage I took it too tried replacing all the spark plugs and coils, checked for an air leak, checked the catalytic converters, checked the fuel line... It then went to a Jaguar / Land Rover specialist who diagnosed a slipped timing chain.
I have now had the timing chain replaced with the newer tensioners but sadly the car is still unhappy, and the specialist has told me that I am sadly one of the very unlucky ones for which pistons have met valves. I am told the options are: 1) replace the engine with a refurbished or used one. 2) An attempted repair of pistons and valves (high labour time, and still risk that repair won't work), 3) possibly sell the car to the garage and be done with it.
Waiting for quotes for each. Any thoughts? Has anyone else managed to repair one of these engines after that has happened?
Replace the engine with a refurbished 1.They gone give you a warranty on the engine replacement and that's what i'm going to do eventually with this jeep that I took for an estimate and the Jeep dealership said if they replace the engine,it will come with something like a 12,000 mile warranty.I think it even comes with more mileage warranty if you replaced the engine with a new 1.So get that refurbished engine and get that warranty and you can't go wrong.That engine being refurbished gone have all the kinks updated so you'll never have an engine problem again or so you shouldn't
Old Jun 15, 2022 | 06:04 AM
  #28
RichardS's Avatar
I only wish that were true. 🤨
Richard
Old Jun 15, 2022 | 07:01 AM
Richard
That warranty should cover it if it doesn't.Wear and tear should be the only thing that break it from that point on
CaptnJack
Jul 1, 2021 05:16 PM
Andreas Schmieg
May 8, 2021 06:16 PM
bmcinsd
Dec 29, 2020 06:43 PM
Skyhawk22
May 4, 2020 06:13 PM
David Dunaway
Mar 10, 2018 09:20 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
