Slow shift first to second
Old Apr 23, 2015 | 10:30 AM
CobraTink's Avatar
Default Slow shift first to second
I am the new owner of a 2011 XKR175. I love this car. The power/torque is awesome. Whether in "D" or "S" or manually shifting with the paddles the shift from first gear to second gear is a significant interruption to hard acceleration. The rest of the shifts are what I would expect from a torque converter automatic transmission. Since this would be controlled by the ECU, it is something that could be changed/corrected through programming. Is anyone aware of a dealer fix for this?
I am pretty sure that the stumble that I am feeling is NOT the DSC interfering. It does it with the DSC on TRAC and "OFF."
Old Apr 23, 2015 | 01:27 PM
Ngarara's Avatar
The transmission is controlled by the TCM. What you're experiencing is not normal, based on my own experience, and may suggest that something is slowing the 1st-2nd shift. Perhaps the operation of one of the clutches is sluggish because one of the valves in the valve pack is gummed up.
Anyway, if you have a warranty, I'd take it back to the dealer and ask them to investigate & rectify. If it was a private sale, find a ZF gearbox specialist and get them to take a look. It may be that a fluid & filter change on the 'box might help.
Old Apr 23, 2015 | 03:20 PM
Greek175's Avatar
Cobra,
Congrats on the 175 which I also am the proud owner of. It is interesting that you mention that as I was noticing the same thing yesterday and was wondering if it was one of those "learning" features that the car learns your habits and since I have been in traffic a bit lately, maybe that would explain it. I would hope that at 30,000 miles, the car would not need transmission service.
Please let me know what you find out and enjoy your Big Cat.
Old Apr 23, 2015 | 06:37 PM
Ngarara's Avatar
I'll try & double-check how mine behaves, though it's hard to get the back end to stay stuck from zero - definitely can't use full throttle.
Old Apr 23, 2015 | 08:05 PM
DGL's Avatar
DGL
I always down shift to 1st when in "S" at very low speed before stopping at a light or behind a car. I also operated my old 175 in the same manner. I find accelerating and shifting into 2nd is extremely quick on the ZF, faster than any non DCT I've owned and own. I find the ZF transmission feels as quick as my 2014 GT-R I sold. I would have the transmission fluid and filter changed and while they have it opened up check it over.
Old Apr 24, 2015 | 05:53 PM
Cee Jay's Avatar
My 2010 XKR has a bit softer 1-2 shift than the 2-3 and so on while in Drive, but with the Dynamic Mode engaged and in SPORT, the shift firms up to where it should be. I thought this softer shift was normal to reduce the impact that a hard shift has at low axle speeds.
hkmcmast
Nov 29, 2015 06:56 AM
danke
Oct 3, 2015 09:31 PM
hughey
Oct 2, 2015 05:17 AM
dansxj6
Sep 28, 2015 08:02 AM
