Sponsored by: DashLynx
Radio Intermittently Stops
Old 08-14-2018, 11:09 AM
rheimburger's Avatar
Default Radio Intermittently Stops
I am finding that the stereo will sometimes not turn back on unless I turn the stereo off before I restart my 2011 XKR. Does anyone have the same issue?
Thanks,
Rich
Old 08-14-2018, 11:36 AM
Cee Jay's Avatar
Received 5,160 Likes on 3,090 Posts
CHARGE THE BATTERY!
The first and most obvious sign of low battery voltage is pretty much ANY electrical gremlin. If your battery doesn't provide at least 12.6 volts after sitting for many hours, you need to remedy the situation.
First charge the battery using an actual Battery Charger, NOT a CTEK. 10 amp minimum, at least for 12 hours. I'd go 24 myself. It's best to disconnect the battery cables while doing the charge, but if not able to do so, clamp the negative charger cable to the body ground spot in the boot, under the deck cover to the right of the spare.
You don't say what vehicle you have, so I don't know if you have the Battery Monitor hardware which the 2010+ cars have. That's the reason for the ground post.
Old 08-15-2018, 10:02 AM
Mufc's Avatar
Take the car to the dealer, get it fixed first time with out guessing and buying unnecessary parts. Usually cheaper in the long run. Too many "penny wise pound foolish" on here. Probably needs the software reloaded but they can tell you for sure.
Old 08-15-2018, 11:45 AM
Cee Jay's Avatar
Yes, I concede. Dealer repairs ARE quite a bit cheaper than charging a battery. You got me on that one!
Old 08-15-2018, 12:49 PM
I took it to the dealer a while back and they could not replicate the issue.
The battery makes total sense. I just changed the battery last week and haven't noticed the radio issue happening since.
Thanks,
Rich
Cee Jay (08-15-2018)
Old 08-15-2018, 01:06 PM
Mufc's Avatar
Cee Jay, no one is trying "get you" on anything but you might want some medication for your paranoia.
JimC64
33
03-28-2019 05:29 PM
Rhett
04-26-2018 02:38 PM
Bobcameron
09-29-2016 12:48 PM
ixj8it
06-04-2012 01:06 PM
sacrider
02-05-2010 07:34 AM
Quick Reply: Radio Intermittently Stops
