Solar BA5-100-1200-CCA Battery Tester
Old Aug 16, 2014 | 05:51 PM
richzak's Avatar
Default Solar BA5-100-1200-CCA Battery Tester
Having low battery problems?
I bought a Solar BA5 battery Tester. It is totally digital, great readout. The Solar BA5 with test for CCA efficiency. This tester will tell you if CCA is down and if a cell is bad within the battery.
Amazon.com: SOLAR BA5 100-1200 Cold Cranking Amps Electronic Battery Tester: Automotive Amazon.com: SOLAR BA5 100-1200 Cold Cranking Amps Electronic Battery Tester: Automotive
So easy to use, nice readout. Test battery in seconds. Just hook to battery, no batteries needed in device. It powers itself from the car battery.
Worked great,. I got the item idea from another forum member "Hawaii". Thanks for the tip. I watched the video and placed my order. Tested 4 car batteries today.
Now I know my Jaguar battery is good. I do keep a CTEK 3300 attached when not driving the car.
Check out this automotive item for under $47.00.
CTEK also sells the same type of device only at about $85.00.
Amazon.com: CTEK (56-925) 12V Battery Analyzer: Automotive Amazon.com: CTEK (56-925) 12V Battery Analyzer: Automotive
Old Aug 16, 2014 | 07:09 PM
jonscot's Avatar
looks great - just ordered one, plus some more fuse taps ... they seem to disappear with clients ...
Old Aug 20, 2014 | 09:40 AM
jonscot's Avatar
just received it today - and it works VERY well. Decently made for the price, and it works.
I can scan the manual and post, if you want?
jluckcuck
Nov 6, 2015 07:49 AM
Swagguar
Sep 30, 2015 01:34 PM
oldjaglover
Sep 29, 2015 03:27 PM
Jzar
Sep 27, 2015 02:55 PM
