Supercharger coolant pump P2601
Old Jan 30, 2026 | 06:03 AM
Gazinsky's Avatar
Default Supercharger coolant pump P2601
I have a 2008 XKR. I received a number of restricted performance (limp mode) warnings when I pushed the car a bit. OBD II gauge showed P2601 fault code. I replaced supercharger coolant pump with a Bosch 010 pump as advised on this forum, but the problem persists. Next step is to check the relay and wiring. Does anyone know where to find the relay for this pump? All other suggestions welcome.
Old Jan 30, 2026 | 06:48 AM
User 42324's Avatar
From another forum: "Try relay R12B and fuse F24 15A in the power distribution box.".
Old Feb 1, 2026 | 02:51 AM
Gazinsky's Avatar
Thanks.
See attached photo. I have found fuse F24 15A, but not relay R12B. The relays in this box run from R1 to R8 (R1, R2 & R6 are empty). Am I missing something?
Old Feb 1, 2026 | 03:06 AM
User 42324's Avatar
Originally Posted by Gazinsky
Thanks.
I see you've replied to the original answer poster on the other forum. Hope you get it sorted out.
pcolapacker
Oct 28, 2025 07:47 AM
JamBar
55
Mar 8, 2023 12:33 PM
Dwayne Mason
Aug 26, 2021 09:14 AM
Veesixjag
Aug 14, 2021 12:20 PM
Ramondoxfsc
Jul 1, 2019 07:11 PM
