Thermostat swap
Old May 4, 2020 | 08:40 PM
tbaxl's Avatar
Default Thermostat swap
Any last advice before I dive into the thermostat housing replacement tomorrow? I have read the threads on the forum a couple of times but most are older, any new advice/knowledge is welcomed.
Tim
Old May 5, 2020 | 08:09 AM
Jomiltom's Avatar
Tim
I replaced the thermostat and the water pump when I was 100,000 km, but I have no idea how many kilometers to replace the thermostat body. I did not do it.
Anyway I would like to find a metal replacement.
You know if the metal replacement is sold
Old May 5, 2020 | 08:33 AM
Sean W's Avatar
No. The replacement thermostat housings are plastic only and should be changed with the coolant flush per every tech on this site (every 5 years) or certainly if you're changing the stat anyway.
Trying Google Translate as well:
No. Las carcasas de repuesto del termostato son solo de plástico y deben cambiarse con el líquido refrigerante por cada técnico en este sitio (cada 5 años) o, ciertamente, si está cambiando la estadística de todos modos.
Old May 5, 2020 | 10:21 AM
Sovejag13190's Avatar
All engine ? On 4.2 XKR is the same i need replace thermostat hoosing and the thermostat?
Old May 5, 2020 | 12:01 PM
tbaxl's Avatar
Well today was a bust, hoses are locked on hard, will get new hoses on the way to replace as well. I now understand why everyone says it’s a good idea to go ahead and get new hoses.
Old May 5, 2020 | 12:49 PM
Sean W's Avatar
Yes. You have a 14 year old plastic thermostat housing in your engine bay. They don't last forever and you got your money's worth off of the first one. Swap it out when you do the job. I't only another $100 or so.
Old May 5, 2020 | 02:05 PM
NBCat's Avatar
The water outlet, which includes the thermostat, on the XKR is metal.
Old May 5, 2020 | 02:19 PM
tommytess's Avatar
Default Replace
Like others have said,replace the whole outlet housing which comes with temp sensor and thermostat already installed on the N/A 4.2.
Old May 5, 2020 | 03:22 PM
Sean W's Avatar
My mistake. I thought this was one asked and answered as plastic. Thx for the correction.
Old May 6, 2020 | 08:35 AM
Jomiltom's Avatar
Thank you. I'll keep it in mind
Old May 6, 2020 | 04:37 PM
AlexJag's Avatar
Sponsor
If you're looking for a more fail-proof thermostat without the rubber that goes bad, also can have them in factory or reduced temperatures.
Pm me
I'm referring to the 3-piece thermostat that's common on 4.2 cars
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old May 10, 2020 | 04:33 PM
Jomiltom's Avatar
Pm me
But if that case is not metal, what changes to prevent it from being damaged?
Old May 10, 2020 | 05:01 PM
Cee Jay's Avatar
I was seriously considering making a crap-ton of milled aluminum thermostat housings for the 4.2 to sell to all you guys. Can't now, lost my access to a mill.
Old May 10, 2020 | 05:55 PM
AlexJag's Avatar
Sponsor
I don't comprehend your question
__________________
Old May 10, 2020 | 08:05 PM
Ranchero50's Avatar
Hopefully AlexJag found a single piece T-stat. The factory one requires the plastic housing to hold the spring pressure and that's why the tabs fails, especially if it ever overheats...
Old May 10, 2020 | 10:36 PM
AlexJag's Avatar
Sponsor
Ahh my bad I misunderstood then. I was only dealing with xkr with sc so they all have aluminum housings, but thermostat which is the three piece design , the insert has rubber around it and this is one of the failure points . The one I have eliminates the rubber all together , only metal is used on the insert I have .
__________________
Old May 11, 2020 | 09:43 AM
Panthro's Avatar
They already make an aluminum thermostat crossover housing for the NA version, but for the Land Rover Range Rover 4.4L engine. Part #'s LR005767, LR002454, & LR003524 respectively. Try searching eBay. (PS: same part is on the Aston Martin V8 Vantage, but at an Aston Martin markup price)
Old Jun 26, 2020 | 07:12 AM
Rikki Rose's Avatar
I tried to translate it as accurately as possible into Spanish and used TheWordPoint service from this review https://pickwriters.com/official-translation-services for this:
Thanks for the translation and for the information, I did not know that when replacing, a flushing is needed for each tech.
Old Jun 26, 2020 | 09:37 AM
Sean W's Avatar
Can you clarify this please Panthro? Are you confirming that the part numbers above fit the XK N/A 4.2L? Assume that's what you're saying but you know what happens when we assume.
Old Feb 2, 2021 | 03:23 PM
Jomiltom's Avatar
Pm me
You say you know where to get a lower temperature thermostat for the xk 4.2?
I would appreciate it if you could tell me where to buy it, in Spain I only find the original thermostat and I prefer to install a lower temperature one.
