Tired XKR Convertible - Tyres and alignment
Old May 10, 2024 | 09:23 AM
justinhill's Avatar
Default Tired XKR Convertible - Tyres and alignment
I haven't been around here for ages - too distracted by work. But the tired XKR has been running well with no problems. I've just had new tyres fitted - my biggest single expense on this or any other car for quite some time. £900 for a set of Continental SportContact 7s.
After which, I thought I should have the alignment checked. As expected, the rear camber isn't great. Presumably there's nothing to be done about it though...
Old May 10, 2024 | 02:41 PM
jahummer's Avatar
@justinhill What rear camber would you like to see? Negative rear camber provides better handling. Yours appears to be within spec of any other X150 I've seen.
Old May 10, 2024 | 03:08 PM
justinhill's Avatar
@jahummer That’s a comfort. I’m aware that some negative camber is a good thing. I had just assumed the rear camber should be within the specs published by Jaguar or something’s broken or worn out. You reckon these numbers are no cause for concern then?
andym55
Apr 12, 2022 06:50 PM
AlexJag
Dec 7, 2019 02:31 PM
Bcrary3
Sep 12, 2018 10:01 AM
jagxkrtoofast
May 10, 2010 08:42 AM
gdrag
Aug 21, 2009 10:14 AM
