Transmission fluid and differential oil source
Old May 30, 2012 | 01:18 PM
Chaos236's Avatar
Default Transmission fluid and differential oil source
  1. 50,000 miles and want to change both. Saw it on here the other day and need to get both for my Indy.
  2. Thanks.
  3. Gregg
Old Jun 3, 2012 | 08:16 PM
2007 Rick's Avatar
Default Oil supply
  2. Thanks.
  3. Gregg
Eriksson Industries 800-388-4418 If it's the ZF 6HP26 tranny the FACTORY recommends 60K mi. and the major suppliers recommend 100K unless it's seen track use. There is enough gray area out there, regarding fluid, that ZF Lifeguard really should be used.
Old Jun 4, 2012 | 10:43 AM
mosesbotbol's Avatar
Change the pan/filter when doing the tranmission fluid change. Fluid and pan are sold as a kit. There's a sticky on this forum somewhere (XJ350 forum). Not very expensive to do at all.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
kstevusa
Sep 7, 2015 01:12 PM
pnwrs2000
Sep 3, 2015 11:55 AM
