upgrading to new shape key fob
Old Aug 23, 2019 | 03:41 AM
George05's Avatar
Default upgrading to new shape key fob
Any one done this ?
Old Aug 23, 2019 | 07:20 AM
George05's Avatar
Had bought a cheap key fob (new shape) from ebay . Just to see if i could transfer the circuit board and other bits from my spare old style XK key fob , Into the new shape fob . I have been using a very hot knife to melt and trim bits away from inside the newer shape fob to see if i could fit mine in , it more or less will fit in but now have 2 sides of the circuit board to trim off with a tool from the widest end of circuit board . It could fit
Old Aug 23, 2019 | 07:33 AM
jagtoes's Avatar
I guess I'm missing the point here. Maybe if I see the final product I'll get what you are trying to do. Compared to my Lexus FOB I find the Jag one to be much lighter and easier in the pocket.
Old Aug 23, 2019 | 10:20 AM
Cee Jay's Avatar
Ok, so then what happens when you're out somewhere and the "INSERT KEY INTO SLOT" or whatever thing shows up cuz Dead Battery or something? New one won't fit into the emergency slot.
Old Aug 23, 2019 | 05:02 PM
George05's Avatar
I like the look of the new key compared to the old flimsy current one . i read some one done it using the old heavy key fob from the x351 xj . But will try this out . (might not be able to but hey ho ) in the new shape fob they have a shorter key inside the fob . xj, xf,xe ftype etc all have same fob now LR to . would just get the blank key cut . got bits to trim yet and could ruin the spare fob worse case , But give it a go
Old Aug 23, 2019 | 05:44 PM
Stuart S's Avatar
If you want the new style Smartkey, do what I did.
Old Aug 23, 2019 | 05:57 PM
jagtoes's Avatar
OK I give what do the different key FOB's look like.
Old Aug 23, 2019 | 07:17 PM
George05's Avatar
Hi was it yourself who done the x351 fob ?
Old Aug 23, 2019 | 08:18 PM
Stuart S's Avatar
Mine came with the XJ.
Old Aug 23, 2019 | 08:21 PM
Stuart S's Avatar
See the OP's Post #1. The XK fob is on the top, XJ fob on the bottom.
Old Aug 24, 2019 | 02:16 AM
George05's Avatar
ok i understand
Old Aug 24, 2019 | 02:28 AM
Sovejag13190's Avatar
I have had the same idea. i don't know why change fob.
Old Aug 24, 2019 | 11:40 AM
George05's Avatar
I just like the look of the new fob . simple
Old Aug 26, 2019 | 08:50 AM
110reef's Avatar
This^^^
Old Aug 26, 2019 | 04:54 PM
George05's Avatar
Have decided to leave doing this mod. The next step involves trimming the circuit board to make it fit inside the new fob and i simply do not want to waste my spare key fob . Would cost me over a £100 to replace so Wont.
Old Aug 26, 2019 | 07:08 PM
Stuart S's Avatar
Put the money you just saved towards a used XJ and you'll have the key of your dreams!
Old Aug 30, 2019 | 02:03 AM
litteredwithfaults's Avatar
This is a good idea because the old fobs turn into trash too quickly.
For testing purposes, how about getting a spare fob? It can be tested if it still transmitting signal before and after the PCB is cut without having it be programmed to any given car. Wondering if the buttons line up and be as responsive when pressed.
Old Aug 30, 2019 | 03:24 AM
George05's Avatar
No xj well not the Infamous x351 version . littered with faults would rather buy the s class merc
Old Aug 30, 2019 | 09:39 AM
Stuart S's Avatar
My XJ and your XKR share the same 5.0L SC engine, which is known for defective water pumps. Other than that, my 2013 XJ has not been "littered with faults" as you claim. If you want a brand that is littered with faults with frequent and expensive repairs, look no further than any out-of-warranty MBZ, and particularly the S-Class.
https://www.bbb.org/us/nj/montvale/p...813/complaints
2015 Mercedes-Benz S550 | CarComplaints.com
https://www.consumeraffairs.com/auto.../mercedes.html
Old Aug 30, 2019 | 01:04 PM
Sean W's Avatar
Sorry, don't want to dis you or the OP but this is anything but a good idea. It's been mentioned more than once and if you own an XK long enough, the car WILL tell you at some point to insert the smart key into the starter control unit. Mods are fine but this one, not so much.
