VVT / timing chain problems
Old Jan 29, 2021 | 04:51 AM
George Abitbol's Avatar
Originally Posted by NBCat
If the engine oil is changed frequently and the oil meets Jaguar specification, then the engine should function normally. Bear in mind that while the AJ33/34 and the AJ133 are well designed, there is always the possibility that failures can occur. These failures are not unique to Jaguar designed or Ford engines.
So there's no specific time / mileage when the timing chain / chain tension should be checked as long as the engine oil is changed in due time?
Old Jan 29, 2021 | 06:34 AM
guy's Avatar
guy
not to mention this is not an ecoboost engine.
Old Jan 29, 2021 | 10:00 AM
Not sure I understand what you mean...
Old Jan 29, 2021 | 11:26 AM
NBCat's Avatar
That is correct. There is no service interval for inspecting the timing chains, guides and tensioners.
Serlock
Mar 20, 2016 02:07 PM
chri15d
Dec 2, 2015 02:32 PM
Baker68
Jun 28, 2015 10:38 AM
blackwolf560
May 3, 2012 04:50 PM
stype2000
Jan 11, 2009 04:40 PM
