What GLUE to use??
Old Jul 14, 2022 | 05:04 PM
bamaboy473's Avatar
Default What GLUE to use??
Hi everybody, new XKR owner here, 2008 with 92K miles but looks like it has 5k miles, outside and inside. Prior owner must have been Casper the
Ghost because the seats and center arm rest are almost perfect. My last car was a 911 with 19K miles and the leather looked about as new as Jaguar leather, so this was a nice change.
Sorting out the cars has been simple and successful except for one thing.......... seems that the PO hit a deer and it caused the right front headlight to snap the two tabs that secure it to the frame. He bought a replacement light but didn't know that they come with and without the Turning Motor, and got one without. While it looks fine, the dashboard light blinks constantly.
His old light (which he saved, along with the pieces of tabs) needs to go back onto the car. Prior to doing a lot of work making the tabs correct, I hooked up the light and.....rats, the blinking light continues. That's another problem for later.
For now, I need advice on what kind of adhesive will bond those plastic pieces. SuperGlue? nope. Epoxy is still soft after 2 hours. Heat/flame should have melted and then cooled to a solid piece, but didn't.
Can somebody suggest an adhesive that will dry hard and bond that kind of plastic? There is ample room to lather the stuff on in order to make a secure connection, but who has found a good adhesive?
Old Jul 14, 2022 | 05:09 PM
Cee Jay's Avatar
Glob on some JBWeld all around it, it will stay put for a good long time. If you don't want to use the liquidy two-part stuff, get a stick of the moldable squish tube stuff. It's like a stiff clay after mixed, you can form it into any shape and it won't move. It hardens like a rock.
https://smile.amazon.com/J-B-Weld-Wa...56&sr=8-8&th=1
Old Jul 14, 2022 | 06:03 PM
bamaboy473's Avatar
great idea, and I've used JBWeld before and forgotten how hard it can get. Instead of focusing on a clean patch, the JBWeld can be formed around the clips and then sprayed black if need be. It can also be filed and sanded to make a better appearance. Thanks, Cee Jay
Old Jul 14, 2022 | 08:13 PM
Gator8's Avatar
Rhino Glue was suggested for repairing the window on my convertible top and I’ve been very pleased so far.
Old Jul 14, 2022 | 08:16 PM
Gator8's Avatar
By the way, Rick, check out South Alabama British Car Club, sabcc.org. We meet in Daphne and have a show every October in Fairhope.
Old Jul 14, 2022 | 08:22 PM
bamaboy473's Avatar
Thanks for the invite. We'll try to take both Jags over next October
Old Jul 14, 2022 | 08:24 PM
bamaboy473's Avatar
I'm perplexed with the type of black plastic being used; maybe it has teflon in it. Super Glue doesn't harden, nor does Gorilla Epoxy, and flame that melts it doesn't allow the pieces to fuse when pushed together. It would be great to have a glue that works, because JBWeld is great stuff, just is more unsightly than a simple glue.
muttony
May 27, 2023 07:47 AM
gijoe50000
Apr 21, 2021 05:11 PM
Spikepaga
Aug 8, 2019 12:50 AM
XK8 Rebel
Apr 19, 2018 09:43 PM
zimt
Apr 8, 2014 07:29 PM
