What Order do the 2 wires that connect to the blower under the dash of my XK go in.
Old Jun 13, 2024 | 11:27 AM
Spokesrooster1's Avatar
Default What Order do the 2 wires that connect to the blower under the dash of my XK go in.
Last night my blower quit working on the heater and air conditioner. I noticed the two wires were disconnected under the passenger side –. I believe one is white and one is green. Does it matter when they are reconnected which blade that they attached to. The blower still does not work. Thank you.
Old Jun 13, 2024 | 02:35 PM
Sean W's Avatar
White is + battery supply from fuse F34 in the aux box. Green passes through to the control unit.
Old Jun 13, 2024 | 03:56 PM
Woo5ie's Avatar
Take the blower out and connect 12v to it to test it
It’s probably the voltage control unit which sits next it. Under the dash
This unit has a thermal fuse in it which blows if water drips into the passenger foot well and runs through the fan
This is known as the Duckbill fix
plenty of posts on here
If the fuse is blown then the cheaper unit for a Range Rover on EBay is the same for a fraction of the price
clemensx300
Sep 6, 2021 04:06 AM
jag91
XJ40 ( XJ81 )
Jul 10, 2015 08:57 AM
selmawp
US Western
Jun 28, 2012 04:41 AM
tomscob
Nov 14, 2011 07:25 PM
