What's your summer project?
Old Mar 7, 2014 | 12:53 PM
mosesbotbol's Avatar
Crafting some sort of x pipe to replace mid section on exhaust. A buddy works for the fanciest car tuner in my larger metro area. They have an exhaust guy who's top notch. I actually like the stock muffler's look, so don't want to do a whole exhaust.
Brakes, if they need it, but I am hoping for reprieve on auto care costs this season. Taking the XK out of storage this weekend. I hope she starts!
Old Mar 7, 2014 | 01:57 PM
CleverName's Avatar
Originally Posted by richzak
Vince:
Did you see my engine cover I had done in Hydrographic Coating?
If not check it out....
Yup,
I had been looking at the idea for a while, but your thread was the final push I needed....
V
Old Mar 7, 2014 | 02:11 PM
amcdonal86's Avatar
What kinds of costs did you have last season??
I would like to do a midsection on the exhaust, too, but I think I will just wait until next year.
Old Mar 7, 2014 | 02:27 PM
moar's Avatar
3-lifetime sealed! But most people here recommend every 60k miles
I'd like to fix this sentence to :
"But the manufacturer says it must be done by 60k."
Old Mar 7, 2014 | 09:06 PM
amcdonal86's Avatar
I might even wait on the transmission until next year. At that point, it will probably be 65000 miles.
Old Mar 8, 2014 | 01:28 AM
Ngarara's Avatar
Permanently fit my solar-panel battery maintainer to the rear luggage cover, with a relay that disconnects it when the ignition comes on. Also, might sort out the rat's nest of cables for my Valentine One, Road Angel & TomTom into something a bit neater.
Old Mar 8, 2014 | 03:10 AM
Mike V's Avatar
Default Acm
Originally Posted by CleverName
Hummm Summer projects....
1. Drive my Cat.... alot!
2. Repair and refinish my rims
3. Hydrograph my engine cover
4. Install my ACM (which I have had on my shelf for 2 years now...grrrr)
Vince
Hey Vince, I just did #4 this winter. Fun project, pulling the NAV console to plug everything was easy and then I just ran the audio connectors under the glove box, in through the back and mounted inside on the passenger door side of the glove box. I ended up putting the ipod/iphone connector there too since it was easier than running it through the armrest plus I have an old ipod nano that I can leave in there permanently. With the scorsche (sp?) adapter it will charge and I'll only take it out to update the music files.
1 problem: I thought I could add the aux option to the menu using ids/sdd program off of ebay but it won't let me so I haven't been able to activate it unless I go to a dealership.
Old Mar 8, 2014 | 07:25 AM
  #28
amcdonal86's Avatar
Is there a problem with leaving the solar maintainer plugged in at all times?
Old Mar 8, 2014 | 08:55 AM
Ngarara's Avatar
Yeah, the manual said that leaving it connected while the engine is running could damage it. I asked the manufacturer about using a relay, and they said:
The fitting of a relay to the connection between the solar battery maintainer and the vehicle battery will be sufficient to stop damage to the solar panel when the engine is running.
Old Mar 8, 2014 | 10:54 AM
  #30
CleverName's Avatar
Interesting choice using the door... I plan on the center console but with a twist... I have a wireless bluetooth gateway to connect to it, so I wont need to fiddle with wires getting in and out of the car...
We shall see..
I hope I don't need the dealership to activate... Seems most folks that did this on their own didn't have any troubles....
Permanently fit my solar-panel battery maintainer with a relay that disconnects it when the ignition comes on.
Can't you jut put a diode inline instead of using a relay?
Old Mar 8, 2014 | 11:43 AM
  #31
Ngarara's Avatar
Yes, but I have a spare 12V relay lying about. Meh; a diode would be easier, I suppose, but I'd need to guess at the appropriate rating.
Old Mar 8, 2014 | 01:08 PM
  #32
CleverName's Avatar
Unless you have some massive collector (most automotive applications run under 2/10ths of an amp), a simple 1 amp diode from Radio shack should do the trick... $1.49
Food for thought...
V
Old Mar 8, 2014 | 02:53 PM
  #33
Ngarara's Avatar
I was more concerned about breakdown voltage - who knows what sort of transient spikes go across the battery? But I suspect there's probably a diode in the panel itself (there must be some protection against reverse connection), so… yeah, probably fine, especially if I use something like a 50V 1A, and easier to do than a relay.
Old Mar 9, 2014 | 03:52 PM
  #34
flay's Avatar
Originally Posted by M6XKR
Thanks! At first the hardest part was simply to source the parts. I should have researched this first but found out quickly that any parts that are 'riveted' to the car, Jaguar is very adamant about not selling to the public so, I needed to get creative. Once I had the OEM parts, honestly the hardest part was finding time to work on it because I have so many other projects going on.
Also ended up buying the recommended rivet gun that the jaguar repair manual recommends, that wasn't cheap. I could have probably used a standard rivet gun and been ok, but I wanted to stick to Jag's repair methods and do everything correctly.
It's been a fun project, and I am looking forward to wrapping it up soon here!
I am very interested in your project, especially in that rivet gun and glue that you used in the repair (make, price, source). A thread with this work is welcomed!
Old Mar 9, 2014 | 07:22 PM
  #35
Versatile's Avatar
Besides oil change, not a lot.
I bought an upper and lower grill set and chrome outside mirrors from Mina Gallery that I plan on installing so that should dress things up a tad.
Old Mar 9, 2014 | 09:31 PM
  #36
Muddydog's Avatar
I bought some strip LEDs from Walmart, so I'll have to find something to do with those. Other than that there's the annual oil change and professional exterior detail. I think I have finally decided I like black wheels. Maybe I'll look into something more permanent in that department.
Old Mar 10, 2014 | 07:08 AM
  #37
Schwabe's Avatar
Re-paint hood.
Paint correction on the entire car.
Eurocharge tune and pulley.
Maybe spend a day at a custom muffler shop and play with some maxflo/flowmaster pots.
Oil change before the summer season here starts.
Old Mar 10, 2014 | 08:45 AM
  #38
A couple of sensors went, rear brake pads, transmission pan had cracked, ac leak, front tires, and a few other things I probably forgot.
Johnken
Apr 8, 2018 10:21 AM
LilaJagHubby
Oct 1, 2015 01:47 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
