Wheel bearing frozen, how do you remove ?
Old Mar 5, 2014 | 08:09 PM
Sunsetaz's Avatar
Default Wheel bearing frozen, how do you remove ?
Have an 2003 XK8, drivers rear wheel bearing is frozen. Help, my mechanic can't figure out how to remove.
Sunsetaz.
Old Mar 5, 2014 | 09:15 PM
CleverName's Avatar
A few here might be of help, but I recommend you post in the section dedicated to your year. This area specializes in 2007 and newer...
BOL
Vince
Old Mar 6, 2014 | 03:05 PM
07XKJaguar's Avatar
Even though this is not in the correct section, your front bearings are pressed into the front steering arm. When I replace them, I usually replace the hub as well. Or look around. The last time I did a set, I found a pair on a rear ended wreck with 20k miles and replaced the whole arms(with bearings/hubs) for less than the cost of bearings and hubs.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
AL NZ
Sep 4, 2015 08:39 PM
Joey T
Sep 3, 2015 05:31 PM
Harry Dredge
Sep 3, 2015 03:04 AM
