Will these rims fit my 09 XKR?
Old Aug 7, 2022 | 11:55 PM
v8moise's Avatar
Default Will these rims fit my 09 XKR?
20" Style 1066 F type R rims. 09 XKR no alcon brakes.
Old Aug 8, 2022 | 05:05 AM
steve_k_xk's Avatar
Yep f-type wheels have correct offset for 4.2 not 5.0 (due to E diff)
20\" gyrodynes in silver
Old Aug 8, 2022 | 08:39 AM
v8moise's Avatar
20" gyrodynes in silver
Okay sweet! Just to double check all the F type rims have the same offset? I would think the F Type R would have wider spec rims?
Old Aug 8, 2022 | 05:58 PM
steve_k_xk's Avatar
After closer examination the Svr are 11" rear with a 54et whilst the gyrodyne are 10.5" rear with a 38et looks like you'll need a 20mm spacer to make things right
Old Aug 8, 2022 | 08:31 PM
v8moise's Avatar
Okay thanks for the help. That wide of rim wheel will fit on an XKR?
Old Aug 8, 2022 | 09:35 PM
steve_k_xk's Avatar
The 10.5" goes on without any issue so I don't see a issue with a further increase of half a inch however due to the different offset your definitely going to need the spacers to push the wheels out on rear for clearance
Old Jun 2, 2023 | 03:43 AM
ozzie209's Avatar
Default F type wheels on my 2008 XK
Hello, I just purchased a 2008 Jaguar XK. The wheels on the vehicle are curbed really bad and are also peeling. I found some wheels off of a F type Jaguar and wanted to know if the wheels would fit. The offset for the front seems to be pretty close to what I have now but the rear is et27. Does anyone if these wheels would fit? Thanks in advance, I’m also attaching a pic of my vehicle and a pic of the wheels I am thinking about purchasing.
SonofGaladriel
Nov 7, 2021 10:38 AM
Rambunctious Jaguar
Jul 6, 2015 07:14 AM
bocatrip
Nov 7, 2013 10:42 AM
tmz_99
Oct 24, 2009 04:01 PM
tmz_99
Aug 23, 2009 04:24 PM
