X150 Front Subframe
Old Jul 7, 2024 | 11:41 AM
gizzmo77's Avatar
Default X150 Front Subframe
Hello,
Does anyone know if the F type front Aluminium RWD subframe (non electric steering rack) has been successfully used on a X150 5.0?
I need to replace mine.
Thanks,
Ed
Old Jul 7, 2024 | 12:40 PM
Cee Jay's Avatar
Yes.
Old Jul 7, 2024 | 01:31 PM
gizzmo77's Avatar
Hi Cee Jay thanks for the speedy response. Is there anything at all that needs modifying or changing?
Thanks,
Eddie.
Old Jul 7, 2024 | 03:46 PM
Cee Jay's Avatar
Eeeee...... I can't rightly remember. At least a few people in here have done this and say it's pretty straightforward.
Try this thread, or search for another...
https://www.jaguarforums.com/forum/x...bframe-258903/
Old Jul 7, 2024 | 04:55 PM
jahummer's Avatar
Thanks,
Eddie.
No, it's a straight fit.
Old Jul 29, 2024 | 03:17 PM
gizzmo77's Avatar
Default Definitive XK X150 to F-Type Front Sub-Frame Replacement
I've now successfully completed the sub-frame conversion. It's not quite as straightforward as made out. Huge thanks to Paul at:
P C Auto's Jaguar Specialist, Aldridge, Nr Walsall for committing to, and completing this conversion.
  • Locate an F-Type 3.0/5.0. The series one, RWD, Hydraulic Steering. The sub-frame is a direct fit. P/N EX53-5019-AH
  • You will also need the rear lower control arms and headlamp auto height adjuster mountings and sensors.
  • The lower control arms from the XK are too wide at the bushes, to fit the F-Type apertures. Replace with the correct F-Type lower (rear control arms inc. bushes). Luckily my sub-frame came with control arms.
  • The lower front Banana control arms from the XK DO fit the F-Type Sub-frame perfectly.
  • The headlight automatic height adjustment sensors and mounting plates are required from the F-Type sub-frame due to the mounting orientation being 90’ out.
  • The original anti-roll/sway bar and steering rack fit the sub-frame perfectly.
  • Keep the original XK headlight height sensors just in case the F-Type ones have a different connector. I had to retrofit my original R/H sensor.
  • The Oil Cooler mounting tray will not fit the F-Type sub-frame, so discard. The oil cooler will screw into the sub-frame rear mounting hole and the front will slot under the retaining tongues. Fit a rubber bush between the cooler and tongues to prevent movement and rattling.
  • Set the geometry as best by eye.
  • You WILL require a full laser Castor, Camber, Toe/track check/set up.
My car handles and drives better than before, this could be due to it needing a laser set up anyway.
Old Aug 6, 2024 | 05:45 AM
jahummer's Avatar
Thank you for the detailed write up. Extremely useful.
Did you happen to weigh them to compare the difference?
Glasgowjim
Apr 2, 2024 05:06 PM
giandanielxk8
Jan 18, 2022 07:43 PM
bil1024
Feb 2, 2017 06:16 PM
Daim
Jan 26, 2017 01:13 PM
