XK Coupe trunk strut question
Hey Jagsters,
Currently when I press the trunk release button on my key fob or on the dash, the trunk unlocks but does not lift up automatically. Is it possible to swap out the OEM struts for and put stronger ones where the trunk would lift all the way up on its own once you unlock it? It certainly would look cool.
Received 1,896 Likes
I don't think it would work as well as you'd like. Look at the geometry of the hatch and strut and notice how the upper mounting points swing through an arc as the hatch lowers. Once the lid is almost all the way shut the shock is being forced closed vs. lifting the hatch. It's just a function of how it's designed. You can buy generic shocks with a higher NM strength and as long as it's closed length will fit when the hatch is closed it'll work. Some even have bleed screws so you can custom lower the pressure if the shock is too strong. We use them a lot in industry.
Alternatively, you could get a pair of the 'rocket launchers' used as 'roll over protection devices' in the convertible, and wire them up to trigger when the trunk is unlatched.
It's probably a one-time-use sort of thing, as your trunk will fly open (and maybe off), so make sure you get a good video of it to post on YouTube.
The alternate is to engineer something akin to SUV hatches power open and close. I think MB has it on many models but it would be homemade. I have to believe it would be pricey but perhaps other car manufacturers make automated trunk open/ self closing for sedans that you could steal from.
FWIW, I replaced my rear struts with OEM recently and have to hold on the the spoiler when I lift. The trunk unlocks as normal but the slightest lift and she just flies up, to the point of making noise at the top stop. They are OEM per Don B, and I'm happy with them but until the old ones completely failed, I was able to hold the trunk at say halfway or three quarters and it would stay. No more. I must hold on to the spoiler. Closing is as easy as ever, so no impact in that regard.
