XKR adaptive headlamp failure
Old Jan 6, 2020 | 04:59 AM
sisut's Avatar
Default XKR adaptive headlamp failure
Hi, I have the common fault of headlights adaptive system failure in my late 2006 XKR (left hand side) which throws up the warning on dash and puts left headlight “down” for safety.
Ive tried the “smack the lamp”, turn wheels fully left and right x 3 etc. but keeps reappearing.
Ive bought a new control module (plugs in the rear of headlamp unit), however, it makes the OTHER headlamp AFS motor run continuously, albeit both now pointing correctly straight ahead.
The module manufacturer tells me I need Jaguar to “code the new module to the other one” to enable system to work, as the module is generic until coded...5DF 008 704. And the XKR has 70 at the end of that code.
Apologies for long thread but is this something that sounds familiar and is it possible to code a module??
cheers, Simon
Old Jan 6, 2020 | 03:20 PM
George05's Avatar
Hi Simon sorry to hear of your problem though small . i have heard of a rather good jaguar indy up your neck of the woods in Paisley they are called Prestige Jaguar . get a very good name i have read on other forums could be worth a drive over not far from Edinburgh . call them on 0141-887-2861
Old Jan 6, 2020 | 03:26 PM
sisut's Avatar
Thanks George,
yes I’ve heard good reports about them and will give them a call if it’s not fixable. Cheers
Old Jan 6, 2020 | 03:31 PM
George05's Avatar
I imagine it would only take an hour or so you could get a coffee etc while you wait . good luck
JayJagJay
Dec 8, 2019 01:27 PM
RoVerto
General Tech Help
Sep 29, 2019 08:43 PM
vlaicu
Sep 3, 2019 01:10 PM
MarkyUK
Aug 23, 2019 10:39 PM
H20boy
General Tech Help
17
Jun 2, 2014 03:51 AM
