XKR oil leak
Old Sep 24, 2023 | 04:02 PM
d a's Avatar
d a
Default XKR oil leak
I seem to have a slow oil leak coming from somewhere around the top front of the engine. I noticed a couple of small drips after about a thirty - forty mile run. Could this be the oil cooler? I don't drive it much but when I do, it drives great. Coolant seems to be OK and gauges don't indicate any issue. I'm planning a SC removal (coupler) soon but haven't seen any mention of oil pipes or hardware up around the front of these engines. thoughts?
Old Sep 24, 2023 | 05:31 PM
racerxf12004's Avatar
It could be the vacuum pump seal. Its located on the lower front part of the motor. But your leak is at the top.. Its a common problem but it a simple fix. I replaced mine when i did an oil change.
Old Sep 24, 2023 | 08:08 PM
rfarmery's Avatar
Maybe the VVT (variable valve timing) solenoid on one or both valve covers.
ray13
Mar 28, 2023 07:18 PM
Gilxj695
Jan 25, 2023 12:40 PM
doowopfix
Apr 14, 2017 12:38 PM
brinny
Apr 22, 2016 07:07 AM
malbec
Jun 20, 2012 01:51 AM
