XKR-S blew all coolant out
Old Dec 7, 2017 | 07:28 AM
GaryTheViking's Avatar
Thanks Ranchero and JagRag,
My car was obviously towed to the nearest Jaguar dealer's service, and just got the quotes from there. Some homework to do before commissioning them...
Old Dec 7, 2017 | 07:48 AM
Ranchero50's Avatar
Per using torque to monitor temps I think it would be much simpler to install an idiot lamp and pick up a basic temp switch. I think that's the route I'm going. I don't care what the temp is as long as it's below the switch thresh hold. I'll drill and tap the aluminum T stat housing and use an old '60's Ford switch that grounds during an O/T condition. Heck, it saved my first '68 Fairlane one summer day running from Orlando to Daytona and had the car in 2nd vs. drive.
Old Dec 7, 2017 | 08:04 AM
jagtoes's Avatar
Ranch being that you replaced the reserve tank and it is the later model there should be a fitting in the bottom for the low coolant sensor. You may want to look there to see if you can rig something up.
Old Dec 7, 2017 | 08:45 AM
Ranchero50's Avatar
Yeah, then I could have two little lights. Orange for no coolant, red for over temp.
Old Dec 7, 2017 | 09:42 AM
Sean W's Avatar
Originally Posted by GaryTheViking
For this very purpose I have an OBDII bluetooth scanner fitted permanently to the port via an extension cable, on which I've cut the power wire and substituted it with a fuse tap. That way the scanner is on only when the car is on, and won't keep draining the battery. On my phone, I have YouBlue set up to start Torque Pro when the scanner is detected, and Torque has an alert set at 100°C / 212°F coolant temp. This way I have essentially automatic logging & alerts whenever the car is running.
I do the same, though not the cable as I use a battery tender. I presume you have it set to open directly to the gauge? probably not necessary with the alarm. I would also advise you set up the voltage as well.
Old Dec 7, 2017 | 04:52 PM
myexcursion's Avatar
How to build a temp alarm
"My XKRS blew all coolant after bursting a plastic part, all in a few minutes after first light came on. So watch the coolant temp, as there's no early warning indication."
Here is an elegant way to do it, thank you Aonsaithya:
i also have an odb gauge plugged in when using the XK, but wouldn't mind wiring it in more permanently if I could locate the power pin on it. Do you have any documentation or write up on which pins and which power on fuse you tapped into ?
Old Dec 8, 2017 | 02:04 PM
Sean W's Avatar
Central fuse box>fuse 17. OBD pin 16
Old Dec 11, 2017 | 01:06 PM
  #28
THANKS ! Now i need to fashion a little on/off switch in there and see how it works
Old Dec 11, 2017 | 01:23 PM
jagtoes's Avatar
I have my scan gauge plugged in the OBDII port all the time and after I turn the car off and lock it the unit shuts off. I assume the OBDII port is also dead as I also have a OBDII ELM unit with a built in switch and on/off light. That also shuts off when I lock the car. So I don't see a need to do the above mod. ????
Old Dec 11, 2017 | 05:16 PM
  #30
Sean W's Avatar
Some functionality programed into your LCD add on I presume. My BT dongle is always flashing. pin 16 is fused battery power.
Old Dec 11, 2017 | 08:39 PM
  #31
jagtoes's Avatar
I beg your pardon but my dongle does not flash.
philwarner
Jan 23, 2021 12:23 PM
Hulsty11
Oct 20, 2017 07:47 PM
burmaz
Sep 25, 2012 09:20 AM
adrian.davis3
Aug 30, 2012 05:56 AM
adrian.davis3
Aug 19, 2012 02:10 PM
