Yet an
Old Aug 26, 2017 | 04:36 PM
Simon Tan's Avatar
Default Yet an
This connector in the link below popped up on my Amazon feed, and it seems like the easiest way to hook up a CTEK that I've seen, but I don't think I've seen anyone on here mention hooking up this way. What's the downside?
Amazon Amazon
Old Aug 26, 2017 | 05:27 PM
Cee Jay's Avatar
The cigar(ette) lighter gets disconnected from power during the power shut-down sequence. No power out equals no power IN.
Old Aug 26, 2017 | 05:36 PM
Simon Tan's Avatar
Dang. I knew it was too good to be true.
Old Aug 26, 2017 | 07:31 PM
jagtoes's Avatar
I use it on my hook up.
Old Aug 27, 2017 | 04:58 PM
ralphwg's Avatar
I use a 6' comfort extension that plugs into the cable attached to the battery/auto. takes all of <15 seconds to plug in and <10 seconds to unplug. I just leave the cord in the trunk when not in use. Very simple and foolproof for me.
Old Aug 28, 2017 | 03:59 PM
kj07xk's Avatar
Have you had any concern about that area on top getting dirty/wet and shorting out between those spade connections?
Old Aug 28, 2017 | 04:57 PM
jagtoes's Avatar
No as the receptacle is a marine socket and the spade connectors are sealed with RTV when installed. I have been through rain and it has not been an issue. There is also a rubber seal plug that you put in the socket when not in use.
