XK120 XK140 XK150 1948 - 1962
found a xk120, could use info on what to grab it for
Old Feb 24, 2019 | 07:26 AM
Axar Patel's Avatar
Default found a xk120, could use info on what to grab it for
Greetings all. I'm new to Classic Jags but, have been doing mustang's and Lincoln's for quite some time.
I fell upon this 1953 XK120 roadster couple weeks back when purchasing a 65 Lincoln and mustang from someone's backyard.
Obviously from the pictures you can tell its been sitting there for quite some time. Haven't had to chance to see the condition of the frame
Owner has a clean title and the 3.8L is in tact and all there.
What would be a fair price to start with on this ? My restoration skills are only so well but, I cant leave this sitting here in the ground either.
Any advise is appreciated.
Old Feb 24, 2019 | 01:30 PM
Fraser Mitchell's Avatar
Hood and doors uncorroded because they are aluminium, but the other panels look to be very seriously rusted, so much so that one must consider that almost all need replacing, plus the chassis as well. So if you do buy this heap of parts, then you need to budget for a very large sum to restore it. XK chassis can now be obtained from Poland, I understand.
You then also will have the engine to restore/rebuild and all other mechanical parts. Not a job that is going to be finished in a few months, so consider years are needed.
FWIW, I rebuilt a Mark 2 in the 80s and it took seven years, and I had an unrusted body shell !! Of course I was doing a job of work in the week, so could only work on the car at weekends and evenings. Most parts are available for XK120s but are expensive.Try searching the internet to see what prices are like.
PS: I'm not trying to put you off, but it would be better if you could find a better example to restore.
Old Feb 24, 2019 | 01:35 PM
Axar Patel's Avatar
think its worth to resell?
Old Feb 25, 2019 | 05:56 AM
George Camp's Avatar
!20s did not come with a 3.8L and the front wings suggest an earlier date--note running lamp pods!
Old Feb 25, 2019 | 05:58 AM
Axar Patel's Avatar
Any chance you'd know what I'm looking at? If I don't pull it out, I am sure the owner will let it decay more
Old Feb 25, 2019 | 06:00 AM
Can you find the data plate under the bonnet? It is a brass plate with numbers for the car!
Old Feb 25, 2019 | 06:09 AM
Axar Patel's Avatar
I can check today when I go to grab the lincoln
chater210
May 28, 2024 08:07 PM
61OTS
XK120 XK140 XK150
Jul 27, 2017 08:49 AM
Damianp
XK120 XK140 XK150
Mar 12, 2017 11:53 PM
jakeperigo
XK120 XK140 XK150
Jun 19, 2014 12:01 PM
HistoryBuff
XK120 XK140 XK150
Jan 7, 2014 05:53 PM
