XK120 XK140 XK150 1948 - 1962
HS8 question.
Old Apr 1, 2024 | 03:42 AM
genneton4's Avatar
Default HS8 question.
Hello. I am tinkering with a '53 XK120 SE OTS. I was 'encouraged' to fit 2" HS8's and I am disappointed with the low down torque (ie off the line power) they have delivered. They are quite a bit better higher up the rev range but I really wanted to improve the off the line power.
It is a 3.4 with an SE head (not C type), both inlet ports reamed to 2". The engine was rebuilt 1000 miles ago. I have trumpets with foam covers. The needles are standard XJ6 BAW. Powerspark ignition.
Is there any way I can dig myself out of this hole. ? Maybe retard the ignition a tad ? Different needles ?
Any wisdoms gratefully received.
Keith
Old Apr 1, 2024 | 03:10 PM
Scd's Avatar
Scd
Hi, perhaps try a set of 3.4 needles, should be either BCC or BCX for the HS8’s, it might be running too rich at low speed. If you haven’t already done so I would put a decent timing light on it and make sure the vacuum and mechanical advance are correct through the rev range. Good luck.
Old Apr 1, 2024 | 08:18 PM
David84XJ6's Avatar
http://solwayjaguar.co.uk/wp-content/uploads/2014/05/Fitting-2-inch-HS8-SU-Carbutettors.pdf
https://sucarb.co.uk/technical/technical-hs-type-carburetter-tuning-general
This article may be helpful
Rgds
David
Old May 29, 2024 | 10:21 AM
genneton4's Avatar
Just for completion.
It turned out to be the Powerspark vacuum advance was faulty.
Replaced with a 123 ignition (GB) version and used advance curve 4.
All is well.
wouldbeowner
75
May 18, 2024 01:49 AM
Syed.A
May 25, 2023 04:46 AM
Joey T
Dec 3, 2022 04:34 PM
woodchip510
General Tech Help
Jan 4, 2022 12:49 AM
90jag
XJ40 ( XJ81 )
Aug 29, 2016 06:19 PM
