XK120 XK140 XK150 1948 - 1962
Rear fender trim
Old Feb 12, 2020 | 10:04 AM
Ted Zoli's Avatar
Default Rear fender trim
On my XK120 there is a piece of metal that appears to be brass that trims the rear fender opening. It has come loose and i assume it is silver soldered to the fender as there are no screws. Does that sound right?
Thanks.
Ted
Old Feb 13, 2020 | 02:52 PM
Ted Zoli's Avatar
More research shows that the part in question is a rear fender wheel arch molding. I don't need the part just attachment advice. Silver solder from underneath when the fender is off will work fine I'm sure.
Trivial issue really.
Old Feb 17, 2020 | 03:24 PM
jaguar38s's Avatar
Original the brass trim around the fender opening was riveted, on the ends were silver soldered.
Regards,
Peter Jan
rfoulds
Jun 18, 2017 01:42 AM
Anthony8858
Feb 13, 2017 05:48 PM
Addy
May 23, 2016 10:13 AM
bocatrip
Feb 12, 2015 10:58 AM
Phil Usher
Jan 10, 2012 06:44 AM
