XK120 XK140 XK150 1948 - 1962
What is acceptable show quality paint thickness
Old Sep 29, 2019 | 04:57 PM
140xkmc's Avatar
Default What is acceptable show quality paint thickness
My 140xk has had total body off restoration and repainted to approx .26mm > 3x factory recommendation. Will the thickness be a problem? It was stripped to bare metal, and the following were applied: base epoxy, primer, adhesive cost, 5 coated of paint and 5 coats of clear. Each were allowed to cure and block sanded between coats.
The doors, hood and trunk are yet to be painted, and I’m getting push back from a new paint shop.
is this typical paint thickness on a show restoration?
Old Oct 1, 2019 | 11:53 AM
Fraser Mitchell's Avatar
I am puzzled why the shop put on 5 coats of finishing paint assuming this is modern 2-pack and not cellulose. It won't do any harm, I'm sure. Of course, in the old days with cellulose, several coats were commonplace, because to get fine finishes and no orange peel, a lot of thinners tended to be used, and this flashes off leaving quite a thin film. Also with cellulose, it didn't give "gloss out of the gun" so much polishing was normal, and this, of course, removes some paint.
Old Oct 13, 2019 | 03:17 PM
Homersimpson's Avatar
It depends on the colour and even paint manufacturer, I've seen cars painted in two coats and one that looked like a fresian cow after nine coats (damask red).
GrahamPhotog
General Tech Help
Sep 6, 2014 01:02 AM
holybananas
Detailing / Car care
Oct 14, 2013 08:02 AM
jagosaurus
Sep 25, 2012 06:50 AM
Wild Bill
Aug 15, 2011 02:50 PM
qwakwak
Feb 8, 2011 01:32 PM
