XK120 XK140 XK150 1948 - 1962
XK120 Brake Master Cylinder
Old Mar 26, 2014 | 06:32 PM
mark.XK120's Avatar
Default XK120 Brake Master Cylinder
Anybody done a conversion on the brake master cylinder for an XK 120?
Tandem. Is there a more modern, available master cylinder that will fit?
Old Mar 27, 2014 | 02:57 PM
Fraser Mitchell's Avatar
There is indeed, and in the US too !
Welsh Enterprises, Inc - Jaguar XK120 Brakes Brake Controls Parts
Old Jun 19, 2014 | 12:15 PM
Nick 53 120 OTS SE's Avatar
Default tandem brake master cyl
While other fitments can be made..the tandem mcyl once set up correctly works well without problems. The usual problems are in rebuilds where the seals are damaged as they are pushed in past the protruding lower edges of the tilt valves. Jag wrote a service bulletin about this,. The other issue is exhaust heat to the mcyl fluid. A heat shield is advised and available (from Basset). Once done..no worries, works well. Rebuild kits are available. Hang on to any original tandem Mcyl..many replacments that are not orig are inferior. Better to always rebuild an orig.
KarimPA
Sep 12, 2015 08:15 AM
Greg Reed
Sep 11, 2015 08:41 PM
Bcrary3
Sep 11, 2015 10:36 AM
1964Daimler
Sep 9, 2015 11:28 AM
obwoodie
Sep 3, 2015 07:45 PM
