XK120 XK140 XK150 1948 - 1962
XK150 Distributor
Old Mar 7, 2016 | 08:21 AM
tonycharente's Avatar
Default XK150 Distributor
Hello to all,
Please forgive me if this has already been covered umpteen times, but my searches didn't find anything addressing my specific query.
I am considering fitting an electronic distributor to my 1957 XK150 that still has a 1957 Lucas DMBZ6A distributor.
The various available electronic distributors refer to slightly later Lucas distributors - I've seen DM6, 22D6, 25D6 and 45D6 for example.
My question is simply would a distributor meant to replace a DM6, 22D6, 25D6 or 45D6 fit straight onto an XK150 (albeit with the wrong advance curves of course)?
Many thanks
Tony
Old Mar 7, 2016 | 04:47 PM
Fraser Mitchell's Avatar
The drive slot on the engine and the depth of the housing didn't change at all, only the top part of the distributor. Your proposed electronic fitment should go straight in assuming it is fitted with the correct drive. The slot the distributor drive goes into is slightly off-set as you'll see if you look with a torch. Your new distributor has to have that.
Of course it may not have the correct advance curve as you say, but a lot of this electronic stuff is software based nowadays, and doesn't use springs and weights in the distributor itself.
Old Mar 8, 2016 | 09:48 AM
Hello Fraser,
Thank you very much for your reply - very helpful.
Sarc
Oct 21, 2017 08:47 PM
OzXFR
Mar 3, 2016 02:45 AM
adenshillito
Feb 23, 2016 12:16 AM
NathanDD6
Feb 22, 2016 07:22 AM
JessN16
Feb 13, 2016 05:09 AM
