If your trunk (boot) lights are out...
Old Dec 12, 2012 | 08:34 AM
Sambo21's Avatar
Default If your trunk (boot) lights are out...
this may be of some help.
My lights and "trunk open" dash display hadn't worked for a few years so I decided to fix. I assumed it was a bad switch so I ordered and installed it. The lights went on so, satisfied with my job, I closed the trunk then reopened it ... no lights! I popped the switch off the latch again and tried it in my hand while still connected to the harness. It worked perfectly.
This switch has a "hook" that goes into the latch first, then snaps in. I made certain that it was snapped in FIRMLY, wiggling it around while pressing it in. I have opened and closed the trunk at least twenty times over the course of two weeks since finishing the job and it now works perfectly every time. Later I checked the original switch with an ohmmeter and, of course, there was nothing wrong with it.
I hope this will be helpful to those who share the same problem -- do what I should have done in the first place and test your existing switch before spending (wasting) an outrageous amount of money on a new switch. The whole job is very easy.
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
prettydaim
Sep 7, 2015 05:16 PM
02jagstype
Sep 4, 2015 08:20 PM
