Replacing Thermostat Housing and Tower
Old Feb 23, 2012 | 08:24 PM
berlin1977's Avatar
Default Replacing Thermostat Housing and Tower
Just wanted to thank Gus and GGG for their assistance. Your detailed pics of the tower change out was a great help the bent 8 mm wrench was the trick. I did make one small change. I bent one for the open end and one for the box end. I also add a piece of 3/8 in (10 mm) square key stock to the wrenches making them 7 to 8 inches long. This made the wrench long enough to clear the top of the tower. Then used a 3/8 or 10 mm to remove and reinstall the bolts.
Graham thanks for the your help with the drain plug and sensor issue. Cleaned and dryed them out and all the codes cleared.
Life is easy when you have a group of Jag nuts to assist.
Jim
Old Feb 24, 2012 | 01:06 AM
ken qv's Avatar
good deal... i did mine yesterday too!
Old Feb 24, 2012 | 02:27 AM
Is that a black plastic screw cap on your replacement tower?
The one I used, and all the ones I've seen advertised, have aluminium caps.
Old Feb 24, 2012 | 08:47 AM
ken qv's Avatar
Yes... it came with an aluminum cap BUT the seal seems different and i don't remember exactly when/who but a guy that works on these and has for many years says that the aluminum caps have often developed small leaks, but used in conjunction with a new plastic cap= Never a problem. I just took his word for it and threw the aluminum one in my parts box...just in case
Old Feb 24, 2012 | 09:03 AM
I got mine from British Parts UK. The first one they sent was a roughcast finish exactly like yours but the cap wouldn't screw down. There was no chance of a watertight fit.
Sent it back. They replaced it immediately without question and also refunded my postage cost. The replacement was a smooth casting:
Replacing Thermostat Housing and Tower-xk8-4.0-new-thermostat-housing-fitted.jpg
The cap fitted perfectly and the car is now sold but I'll remember your comment on using a new plastic cap if I need to fit an aluminium replacement tower on this car.
Thanks,
Old Feb 24, 2012 | 03:09 PM
Gus's Avatar
Gus
Kudos to you. On the road again.
Old Feb 24, 2012 | 05:34 PM
Jim
Jim,
That 'super wrench' is worth posting a photo with measurements for those who are looking to solve the same tower replacement problem in future.
Old Feb 25, 2012 | 10:44 PM
EZDriver's Avatar
Are we talking about a new designed plastic cap or just a new one of the existiong design?
Old Feb 28, 2012 | 12:17 PM
2000CAXK8's Avatar
I am gonna be getting my tstat house via UPS in the next 5 hours or so...
Question: Can I siphon the coolant out of the Thermostat or do I have to remove the plug from the bottom of the radiator?
Old Feb 28, 2012 | 12:25 PM
Gus's Avatar
Gus
Draining it from the radiator is the right way to go.
Old Feb 28, 2012 | 01:23 PM
2000CAXK8's Avatar
Grrrr, I looked everywhere and can't find the drain plug. Is it hidden by the snow dam?
EDIT: looks like its on the back of the radiator facing the passenger seat. I was expecting it to be on the bottom facing down.
http://matt.zenfolio.com/xk-coolant-...tat---v1-1.pdf
Old Feb 28, 2012 | 01:36 PM
The radiator drain plug is lower right hand side facing towards the engine. You're looking for a black plastic plug with a crossed slotted head:
Move to one side as you undo it.
Old Feb 28, 2012 | 03:49 PM
2000CAXK8's Avatar
well I hit a minor hiccup. I drained the radiator via the plug on the bottom of the radiator but because the thermostat is cold and closed there is coolant filling the bottom half of this:
I think i'll have to siphon that out after all
Old Feb 28, 2012 | 04:14 PM
Gus's Avatar
Gus
I think you will find the coolant leakage is minimal at this point just open it slowly.
Old Feb 28, 2012 | 05:13 PM
Try to avoid coolant spillage over the serpentine belt either by wrapping with a large plastic bag or removing it. Once these have had coolant on them they start to squeak.
Old Feb 29, 2012 | 03:43 AM
.........the bent 8 mm wrench was the trick. I did make one small change. I bent one for the open end and one for the box end. I also add a piece of 3/8 in (10 mm) square key stock to the wrenches making them 7 to 8 inches long. This made the wrench long enough to clear the top of the tower. Then used a 3/8 or 10 mm to remove and reinstall the bolts.
Jim
Photos of berlin1977's wrenches:
Clearly shows the bend needed and how the square key extension makes it easier to remove and reinstall the bolts.
Thanks to Jim for this.
Old Mar 2, 2012 | 10:25 PM
berlin1977's Avatar
Thanks Graham for posting the pics, I am sorry that I have not responded sooner but it has been on of those 70 hr work weeks. Gus had used/cut a slot in the bolts so a screw driver could be used. Which differently made the instalation easier. But I did not have a vise to cut the slots in the bolts. I had bent the 8 mm wrench and tried to use the vise grips but could only get about a 1/8 of a turn on the bolt. I purchased a second 8 mm wrench and bent them for open and box end. added the 3/8 in or 10 mm key stock to the back off the wrench which gave additional clearence from the tower. With the key stock it made the wrench between 7-8 inches in length, which cleared the top of the tower. (1 st. pic) Used a 3/8 in or 10mm wrench on the key stock to remove the back 2 bolts. Like the old saying "There is more then one way to skin a CAT!!" My cost was around $26 bucks. I hope this helps Jim
Old Jun 7, 2014 | 12:07 PM
Richy_T's Avatar
Just replaced my thermostat housing with the aluminum one yesterday and now it's leaking at the top. :/
Old Jun 7, 2014 | 03:27 PM
RJ237's Avatar
There have been a number of reports on leaking covers. Who supplied the tower? Often the threads are not cut properly, so take the o-ring out and make sure it screws on a little further. If that is not the problem, look for a larger o-ring.
Old Jun 7, 2014 | 03:36 PM
jonscot's Avatar
would a crow-foot wrench on a socket extension fit here - its raining outside, so I don't have the chance to go try it...
