Trunk Release Emblem replacement - source
Old Mar 28, 2015 | 12:21 PM
Jandreu's Avatar
Default Trunk Release Emblem replacement - source
Just passing this along, no interest other than to help with sourcing a small but important part!
I just ordered one and will report back on the quality when it arrives....
They come in all colors...
Jaguar Trunk Switch Badge Sticker Emblem Decal in British Green | eBay
Old Mar 28, 2015 | 02:31 PM
01Silverstone's Avatar
I've just ordered one in black (recently replaced my center caps with black growlers, so now this will match!). Will report back as well. Thanks for the link!
I'm assuming the old one will need to be removed first, so maybe the button/mechanism will need to be removed to do that?
Old Mar 28, 2015 | 03:14 PM
Jandreu's Avatar
Easy to take out the button, put back trunk lid liner, remove 4 nuts holding the trim on and there are two nuts holding the switch to the trim.
Old Mar 29, 2015 | 09:45 AM
jamdmyers's Avatar
No You can use a pick to pull up the old cover it's just stuck on, biggest problem I had was getting the new one centered 'just so' .. I removed old black and replaced with Red to match the rest of the badging.
Old Apr 9, 2015 | 01:21 PM
Good to know. Thanks. I received mine today, so I'll be putting it on tonight. Button looks great from initial inspection- appears to be high quality. I ordered 2 just in case I need to replace it again someday.
My existing one is faded green, so the new black one will match my new black center caps better.
Old Apr 9, 2015 | 05:35 PM
Just put the new button on. Took less than a minute, as I was able to pry the old one off without removing the mechanism as jamdmyers suggested. Some before and after shots. Small but meaningful difference, and for $7 I'm very pleased.
I hadn't realized how faded/discolored the old one was until seeing them side-by-side. Maybe I should investigate a new bonnet badge too..
(the button coloring looks uneven in the second picture, but its just the flash. Last picture depicts it more accurately)
Attached Thumbnails Trunk Release Emblem replacement - source-img_4608.jpg   Trunk Release Emblem replacement - source-img_4609.jpg   Trunk Release Emblem replacement - source-img_4610.jpg
Old Apr 9, 2015 | 07:08 PM
Jandreu's Avatar
Great, mine should be here any day.
Old Apr 10, 2015 | 12:27 PM
rothwell's Avatar
A couple years ago I updated back and front to a more current look.
to match the new center caps
Old Apr 10, 2015 | 06:13 PM
Jandreu's Avatar
Got mine today, sun was so bright I could not get a good pic but it's an exact match and looks great!
Old Apr 10, 2015 | 06:14 PM
Jandreu's Avatar
Rothwell, I like the chrome Growler hood bagge, where did you source that?
Old Apr 14, 2015 | 07:15 PM
rothwell's Avatar
The front badge is DIY using an XF badge and a bezel fabricated from a hydraulic seal.
Because the nose is not completely flat under the badge, I used a polyurethane hydraulic seal and cut the center out of it to make the bezel. It has that smooth machined look with sharp edges but was soft enough to handle the bend and fill in the gap.
So the bezel is just stretched over and snapped around the mounted emblem. No need to glue it.
It's an SKF seal. Part# FSU25-2.50-SQB. About $7
Old Jun 7, 2016 | 08:59 PM
hm1's Avatar
hm1
Seller no longer sells. Anybody else have a source for replacing these?
Old Jun 7, 2016 | 09:44 PM
MediaBobNY's Avatar
Here. But the price is absurd compared to the guy who used to sell them on eBay.
Old Jun 8, 2016 | 04:55 PM
Jandreu's Avatar
Rehire I did replace mine, before I did I used some plastic polish, headlight restorer, on my old one and it cleaned it right up.
JarodL
Mar 7, 2024 01:39 AM
David Thompson
Sep 3, 2015 07:48 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
