"grinding" noise from the front end??
Old Jan 22, 2008 | 10:59 AM
ken@britishparts.com's Avatar
Default RE: "grinding" noise from the front end??
It could be the beginnings of losing a wheel bearing. They are sealed bearings, so you replace them and not just lubricate. Be sure your tech has the ABS nut removal tool. If not, we sell them.
Old Jan 22, 2008 | 12:08 PM
rscultho's Avatar
Default It sounds as if...
Just a suggestion...
Your pads are touching when the wheel/disc is cold, and as they warm up they expand/move apart. I had that occur on another car (not a Jag). If that is your issue, bleeding your brake fluid (putting new fluid in your brake lines) may solve your problem. It's easy to do yourself and is an inexpensive way to try as a fix. Plus, it never hurts to put in new brake fluid.
Old fluid is not as stable temperature wise as new fluid and can casue the calipers not to release as they should at all temperatures.
Good luck.
Old Jan 23, 2008 | 09:03 PM
v8stype's Avatar
Default RE: It sounds as if...
Ken,my car also started started making a squeky sound about a week ago when it starts moving in drive with out hitting the gas the front right tire goes squeak squeak squeak and makes the sound faster when u go faster a local mechanic told me it was probally the wheel hub my question is can i buy just the bearings or do i have to purchase the whole hub assembly.thanks
Old Jan 26, 2008 | 11:19 PM
Jack Rabbit's Avatar
Had that. It turned out to be a a twig stuck up in the under carriage. It blew off after a while.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
robiwhan
Sep 4, 2015 10:43 AM
