`that...bleeping...indicator!!!`
Old Oct 30, 2015 | 08:57 AM
hellokitty's Avatar
Default `that...bleeping...indicator!!!`
Hi Folks,
Re. 2000 XKR
Anyone out there who can point me quickly in the right direction ( no pun intended ).
When i indicate right or left , it is usually accompanied by a pleasant dull ticking sound.........but not always!!
The indicators alway work but not the sound. Should i be looking at the armateur (if so where) or bleeper ,wherever that may be . Its not a life threatening problem but would be nice to have sorted . any advice ?
Cheers nige
Old Oct 30, 2015 | 12:26 PM
RJ237's Avatar
The speaker is on the right side of the lower panel in a LHD car. It may be a bad or dirty connection. Of course, you have to remove the panel to get at it.
Old Nov 6, 2015 | 05:46 AM
hellokitty's Avatar
Hi RJ
hey thanks ,you hit it right on the head. I only looked at the speaker cable and it fell off, so now its soldered and working fine , thanks alot!
nige
Old Nov 6, 2015 | 06:36 AM
marvin.d.miller's Avatar
Wait a tick...there's a speaker for the turn signals?
Old Nov 6, 2015 | 07:17 AM
WhiteXKR's Avatar
Yes, the speaker generates all of these sounds and is driven by the Body Control Module (BPM):
AUDIBLE WARNINGS:
• AIRBAG WARNING
• DIRECTION INDICATORS
• HAZARD WARNING
• SIDE LAMPS ON
• VALET MODE WARNING
• GEAR SELECTOR IN PARK
• MEMORY CHIME
• SECURITY ARM / DISARM
• CONVERTIBLE TOP MOVEMENT (CONVERTIBLE VEHICLES)
• KEY-IN-IGNITION SWITCH / DRIVER DOOR AJAR (NAS VEHICLES ONLY)
• DRIVER SEAT BELT DISCONNECTED
This car does not have a conventional turn signal relay.
Old Nov 9, 2015 | 06:41 AM
Default I'll be danged...
Just when I thought I knew everything...a speaker for the turn signals....
RJ237
Jul 25, 2024 03:20 AM
Lothar52
May 23, 2024 09:54 AM
multistrada74
Feb 15, 2016 07:32 PM
romello424
Oct 30, 2015 07:51 PM
Mommacat
Oct 26, 2015 12:57 PM
