01 XKR transmition fault when going into the J-gate ratios.
Old Aug 1, 2014 | 12:51 PM
JaguarXKR's Avatar
Default 01 XKR transmition fault when going into the J-gate ratios.
Does anyone know what it could be? Could it be the shift linage cable?
Thanks in advance!
Mike
Old Aug 2, 2014 | 08:00 PM
JaguarXKR's Avatar
Originally Posted by JaguarXKR
Does anyone know what it could be? Could it be the shift linage cable? Thanks in advance! Mike
Anyone?
Old Aug 3, 2014 | 07:32 AM
oyster's Avatar
Hi.
You need to read the fault codes. It could be numerous different faults, and without the codes any remedial action is a shot in the dark. As you know these things are very complicated.
Old Aug 3, 2014 | 11:27 PM
enderle's Avatar
Default Sequential Switch
Bet it is the sequential switch. But agreed you need to pull the codes to be sure.
Old Aug 4, 2014 | 07:41 AM
oldmots's Avatar
Without any codes, the first suspect is the rotary switch, the switch on the side of the tranny that the cable goes to, cables seldom fail. There is a module under the console that tranlslates shifter position to digital on the older models, don't know if yours has one or not.
Old Aug 5, 2014 | 05:29 PM
JaguarXKR's Avatar
This problem has happened to me twice, two days in a row. But as soon as I hook up my blue tooth obd2 scanner, it wont show any codes or shoot me the code while going into the J-gate...weird. But if it happens again I will run the codes right away.
Thanks for all your help so far!
tomsjag
Jun 10, 2023 10:02 AM
flyrr100
Mar 14, 2016 06:37 AM
Poet
Oct 6, 2015 09:40 PM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
