03 Fuel Regulator orings leaking, can I buy them?
Put my fuel rails back on and the only o rings I did not replace were the ones on the regulator located at front of passenger rail. Where can I get rings for this unit? Ar they the same as the ones on the intake side of the injectors? Would a parts store have theM???
I hate to buy a new regulator when the rings are all I need.
They aren't listed as separate parts but you might try an autoparts store to see if they have a selection of o-rings to look through.
You could also try a hardware store, Lowes or Home Depot, but check on the fuel compatibility.
OkieTim
Sep 8, 2015 04:48 PM
