04 XKR Hesitation medium acceleration 35 - 45 mph
Old May 6, 2023 | 05:22 PM
Markmbaha1's Avatar
Default 04 XKR Hesitation medium acceleration 35 - 45 mph
My 2004 XKR is having a small hesitation under moderate to low medium acceleration driving 35 to 45 mph. The rpms pick up then drop back for a couple moments then picks up again. If I accelerate harder it takes off fine, like it bypasses something on strong acceleration. City driving you'll never feel it . Fuel filter, MAF, have been changed, air tube is tight on both sides, stock air filter is new. 50k miles Im running some cleaner through today and tomorrow. It may have started aftet I took off the fresh air tube off to inspect it, ckean MAF and inspect filter box, but I replaced the MAF no difference so I took it back. The Specialist EURO car shops say if it has no code we can't diagnose nothing. They drive it and can't feel it. Really, i assured them its there but no code they send me away. Exasperating.
Thank you in advance.
Old May 6, 2023 | 11:15 PM
Johnken's Avatar
Long shot but make sure the bolts securing the air tube to the throttle body are still in place. I had similar issue once when a bolt worked loose.
John
Old May 6, 2023 | 11:20 PM
xalty's Avatar
use the frp sensor it will tell you if you have a pressure problem. then check the many other pids to see if the numbers add up
Old May 8, 2023 | 04:29 AM
Markmbaha1's Avatar
John
Thank you but my Air Tube fastens down with a band that tightens down with a screw adjustment. See pic.
AlexJag
Mar 22, 2017 01:41 PM
omgimali
Dec 26, 2016 09:08 PM
avos
Aug 26, 2011 12:10 AM
rscultho
Jun 4, 2011 03:16 PM
AnthonyF
Jul 25, 2010 11:25 AM
