1996 Coupe, airbag light stays on.
Old May 3, 2016 | 04:09 AM
wal 10's Avatar
Default 1996 Coupe, airbag light stays on.
Hi, my air bag light stays on. No flash code. Appeared after charging flat battery, not sure if this is related. Does this have to be cleared by a code reader or does it mean there is still a Fault there? Have had a good look through previous posts. Any help would be much appreciated. Have tried a Hard reset, Airbag fuses OK.
Old May 3, 2016 | 03:01 PM
Jandreu's Avatar
Check the fuse box on drivers side of the dash. I think it's fuse 10 but not sure, it should be covered by a small clip that none of the other fuses have, top left if I remember correctly. See if it is bad. This happens on my car every time my wife drives it and moves the seat all the way forward.
orangeblossom
Apr 15, 2016 01:05 PM
o1xjr
Feb 17, 2016 06:10 AM
XJsc-guy
Sep 2, 2015 11:43 AM
