1997 XK8 ABS light and DSC / STAB failure
Old Nov 9, 2020 | 03:28 AM
Diederick's Avatar
Default 1997 XK8 ABS light and DSC / STAB failure
Hello, everyone,
My 1997 XK8 unfortunately has the ABS light on and the DSC and STAB failure. This is since I bought the car.
I have read all the forums and tried several things. But unfortunately I can't solve it so far.
After I opened the module and re-soldered the dots, the DSC and STAB faults are gone, as long as the car is stationary. When I drive a few meters (forward) they come back again. The abs light always stays on.
I have measured all the ABS sensors at the wheels, and there they all have the same resistance. But, when I measure the same sensors on the plug of the abs computer, I don't measure any resistance with all 4 sensors!
Does anyone have a similar experience or a good idea how to proceed? I really appreciate your help.
Diederick
Old Nov 9, 2020 | 03:54 AM
Ekskaar's Avatar
Hi,
Did you take out the sensors to clean off grease and metal particles?
If not, pls try.
good luck
Old Nov 9, 2020 | 03:59 AM
Diederick's Avatar
Thank you very much for your reaction
I have already done that. They were already pretty clean when I took them out. Then I cleaned them all. Unfortunately, this made no difference.
Old Nov 9, 2020 | 04:38 AM
Ekskaar's Avatar
Okay, next in line is battery voltage with ignition off, after day of sitting still. (sb abive 12.5 ish ) And then try to monitor during cranking. (I think you can make a histogram with a ELM327?) If it gets under 9v or so the system goes mad..
You probable also did this? In that case pls. post what you did try.
Old Nov 10, 2020 | 06:29 AM
Diederick's Avatar
Okay, I have measured the voltage of the battery.
After a day of standing still I measure 12.22V
At startup 10.8v
So far I have re-soldered the dots in the abs module and cleaned all the wheel sensors and measured the sensors for resistance.
I find it strange that I measure resistance on all 4 sensors themselves, but not on the connector that goes into the abs module.
Old Nov 10, 2020 | 10:10 AM
Ekskaar's Avatar
At startup 10.8v
Strange indeed all 4...(Look for commonalities. Maybe Measuring device probes too thick?
12.22 V is quite low however.
Can you charge it overnight and start the car next day with charger connected? If no messages you know Battery is not what the Jag needs for a good mood😉
Edit: didn't read your posts well. Appologies. You are getting the messages back after reset with engine running. Different story. Dunno whats up.
Good luck
Sama8525
Jul 3, 2015 07:20 PM
scardini1
Aug 27, 2013 08:50 PM
Wolfy
Nov 10, 2012 10:59 AM
Spurlee
Jul 14, 2009 02:46 PM
