1997 XK8 air conditioning charge.
Old May 6, 2013 | 08:23 PM
noterman's Avatar
Default 1997 XK8 air conditioning charge.
After a engine change I finally have everything sorted out and the car is running great. Now its time to charge the AC. THe system was open so I plan on buying a new dryer. Does anyone know the quantity and type of oil I should have in the AC system? I replaced all the ORings, other than the dryer am I missing anything? Thanks
Old May 6, 2013 | 10:17 PM
SPIJohn's Avatar
There should be a sticker under the hood on the right side shock "tower" which gives you the refrigerant charge & oil info. Mine says 1 lb 12 oz of R134a. The oil to use is "PAG", however JTIS states that when replacing the dryer you do NOT need to add any oil.
-John
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Dec 4, 2020 07:55 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
convincor
Sep 10, 2015 06:50 AM
