1997 XK8 coolant crossover pipe seals
Old Jul 9, 2019 | 12:48 PM
TheCounty's Avatar
Default 1997 XK8 coolant crossover pipe seals
Anyone have the part # for these 2 seals, one on each end of the coolant cross-over pipe in front of thermostat housing. It does not appear on my parts list & aftermarket suppliers seem to be confusing these with the thermostat o-ring or the larger seal under the thermostat housing.
Thanks in advance.
Old Jul 9, 2019 | 02:21 PM
Johnken's Avatar
Is this #21 what you mean? John j
Old Jul 9, 2019 | 02:34 PM
TheCounty's Avatar
Would be similar to #22. That assembly pic is from an XKR or 2003 & later model. My 1997 has no thermostat fixings in the crossover.
Similar attachment to head I believe and likely same seal. Can someone confirm?
Old Jul 9, 2019 | 03:25 PM
RJ237's Avatar
yes, it's C2C11477.
Old Jul 9, 2019 | 03:28 PM
michaelh's Avatar
Original part NCA2268BC. Heritage site, which also shows the 'wrong' diagram, lists latest part # as C2C11477 but NLA.
https://www.jaguarclassicparts.com/uk/part/NCA2268BC
I imagine your looking for 10 here:
Forum sponsor SNG Barratt has them:
https://www.sngbarratt.com/us/#!/Eng...1-80d70c981eec
IIRC the OEM water outlet (AJ85885 - 9 above) comes with the seals. Consider changing the whole thing if yours is of any age. It's not expensive & also complete with new temp. sensor.
Old Jul 9, 2019 | 07:38 PM
TheCounty's Avatar
Thanks to all.
SleekJag12
Mar 6, 2020 02:20 AM
Ter11
Nov 17, 2018 02:36 PM
Asdrewq
May 27, 2016 05:36 PM
XJsc-guy
Aug 10, 2015 11:03 PM
Viapa
Aug 7, 2011 10:50 PM
