1997 xk8 stall
Old Dec 29, 2011 | 10:57 AM
Rip Reed's Avatar
Default 1997 xk8 stall
I have a 1997 xk8 it will stall when it gets to operating temper when you shift in to drive and reverse Need Help Thanks
Old Dec 29, 2011 | 12:00 PM
dr_jekyll's Avatar
they can sometimesstall due to a throttle body fault , this is where i would look first.
Old Dec 31, 2011 | 09:27 AM
GordoCatCar's Avatar
Are you getting any dash indicators or warnings? Have you put a code reader on the OBD port? Engine stalling can be caused by many different problems. Too many to guess, so you need to narrow down the range by troubleshooting for some codes.
Old May 21, 2013 | 01:22 AM
bskahj's Avatar
Mine always get the "traction control" warning on, and then stalls when swithing gears and after a little run, is that all the throttle body?
Old Jun 6, 2013 | 08:14 AM
DCCapitals's Avatar
So did you solve the problem ??
Old Jun 7, 2013 | 10:01 PM
bskahj's Avatar
Not really, it stills seems like the carbo is better (I got it cleaned out). I still think its more like a problem with the gearbox or the actual traction control tho
kingdom worker
Nov 14, 2020 03:47 PM
speacock
Oct 3, 2015 11:15 AM
JaguarSV8
Oct 1, 2015 01:58 AM
Mark SF
Sep 28, 2015 01:51 PM
42Ajd
Sep 26, 2015 07:04 PM
