1997 XK8 Tail light assembly - ground melted - with pictures!- RESOLVED
Old Mar 3, 2013 | 05:48 PM
linkspider's Avatar
Default ? for hacker-pschorr
hacker-pschorr I take it that extra wire you put on is a ground?
If so are you connecting other end to body of car?
My female plug just burnt out the same way except terminal 1 in line on both sides burnt out I think I may need a new plug as particular burnt out one the metal crumbled or can I solder a wire direct?
Old Mar 4, 2013 | 07:15 AM
WhiteXKR's Avatar
Here are the answers:
1: Yes.
2: Yes
3: If you are adding the bypass wire to ground terminal 1 is no longer used so you do not need a new connector.
Old Mar 4, 2013 | 07:34 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'.
Old Mar 5, 2013 | 05:26 AM
linkspider's Avatar
Thanks I will give it a try
Just to verify when I say terminal 1 I am talking about the first hole in the female plug that burnt out that would attach itself normally to first male prong on left I am going to attach an earth lead to that one direct to bodywork; correct ?
Old Mar 5, 2013 | 05:37 AM
You should ignore the extreme right hand contact in this pic
and take an earth from anywhere on the ground part of the light to car body ground.
The light ground is the large bit of metal that goes around the outside of all the bulbs.
Attached Thumbnails 1997 XK8 Tail light assembly - ground melted - with pictures!- RESOLVED-img_1694s.jpg
Old Mar 6, 2013 | 04:57 PM
linkspider's Avatar
Default Seems to have fixed my light problem
This fix actually seems to have fixed the problem; shoot me down anyone if you think this is a mistake.. Thanks for the solution
Attached Thumbnails 1997 XK8 Tail light assembly - ground melted - with pictures!- RESOLVED-jag%2520rear%2520light%2520fix.jpg
Old Mar 6, 2013 | 07:39 PM
WhiteXKR's Avatar
Thumbs up
Looks like you nailed it!
Old Mar 8, 2013 | 03:02 AM
  #28
Good job.
This thread is already in the HOW-TO section FYI
Old Apr 27, 2014 | 02:32 PM
Tauni_XK8's Avatar
Update:
I implemented the GND wire connection from the light assembly to the mounting bolt, checked for continuity to GND to ensure a good connection.
Unfortunately, that did not solve the problem. Directional indicator on dash still flashes at twice the normal rate.
A good thing to do anyway, thanks for the tip.
Sigh......... Now what....
Old Oct 5, 2014 | 05:26 PM
  #30
b6283's Avatar
I had this problem and tried this ground wire fix but it didn't work for me.
So, I switched every bulb from the right side with the bulbs on the left side and the problem stopped! Weird, but as long as it works...
Old Sep 3, 2016 | 05:38 PM
  #31
dgm309's Avatar
Default Finally!
Guys, I can't begin to thank you enough for this solution!
I've spent the last 16 years chasing the electrical demons lying within my 98 XK8's rear lights - from the typical rear backup light not working (when the bulb was fine), rear turn signals going wonky when you step on the brake (then the weirdness switching from one side to the other side and then later working normally for months).
I was about to head to the dealer and have the harness replaced when I saw this post the other day and voila my baby is now purring happily!
Thanks again!
Old Nov 4, 2017 | 09:18 PM
  #32
Kippyald's Avatar
Thank you! Was just about to buy a new connector and light cluster but this solved it! I'd been having a 'bulb fail' message for a while and after changing all the bulbs I found the shorted ground connector but hadn't considered bypassing it like this - excellent solution!
Old Feb 22, 2018 | 03:35 PM
  #33
nay64nay's Avatar
Default connector
Does anyone know where I can purchase the taillight assembly connector for mu 1997 xk8?
Old Feb 22, 2018 | 04:14 PM
  #34
nay64nay's Avatar
Im gonna try this
Old Feb 22, 2018 | 06:35 PM
  #35
nay64nay's Avatar
Default connector
it worked!
Old Sep 12, 2018 | 01:56 PM
  #36
magnum454's Avatar
I had the same problem. The addition of the aux. ground wire (example below) solved the problem.
Old Sep 12, 2018 | 01:59 PM
  #37
magnum454's Avatar
By the way, I lifted the carpet near the tail light, scraped the paint off, drilled a hole in the metal and screwed the wire to the floor.
Old Oct 25, 2018 | 01:13 PM
  #38
tlynch's Avatar
It was finally my turn.I got the "Bulb failure" message if I used the right turn signal while braking, or any time the rear fog lamps were on.
British electrical connections at their finest.
I riveted a wire to the ground plate, scraped some paint away from one of the bolts that hold the rear light lens assembly in place, and all is well. I'll do the left side soon.
Tom
Old Jul 5, 2019 | 11:02 AM
  #39
piper 888's Avatar
Great idea, this forum is invaluable and the ingenuity is priceless! I'm a newbie to the XK 8 and have owned Jags since 1970 but find the electrical issues in the XK 8 are very complicated for an old dog like me.Thanks again to all of you for sharing your fixes.
Old Dec 19, 2019 | 08:14 PM
  #40
b6283's Avatar
I've had intermittent problems with my added ground wire (poorly wound around the cluster by me). Warning light on for the past 3 months no matter what I did with my ground wire. LOL, I actually had two burned out brake light bulbs! I was so used to the complicated problem, I overlooked the obvious! All good now.
