1998 XK8 Rims
Old Jan 19, 2018 | 06:51 PM
Flipr78's Avatar
Default 1998 XK8 Rims
hi everyone. I am curious if it's possible to fit Borbet Tiger Claws than 1998 xk8
the dimensions are as follows:
2- 19x9 et.48
2- 19x10 et.45
not sure what it will will take to put them on my jag if possible.
Old Jan 20, 2018 | 04:35 AM
I have no idea but the Borbet Tiger Claw on a Cat sounds like a perfect match.
Old Jan 20, 2018 | 02:21 PM
Flipr78's Avatar
Any tire/rim specialists out there??
Old Jan 20, 2018 | 02:23 PM
Flipr78's Avatar
I think they would like great and I can get them cheap....
Old Jan 20, 2018 | 04:53 PM
giandanielxk8's Avatar
2- 19x9 et.48
2- 19x10 et.45
It all depends on the following:
  • Bolt pattern (5 lugs x 120.65 mm on the XK8)
  • Offset ET between 30 to 33
  • Rim width (between 8 to 9)
The recommended rim sizes are:
  • 8J x 17 ET 33 using 245/50 R17 tires
  • 8J x 18 ET 33 using 245/45 ZR18 tires
  • 8.5J x 19 ET 33 using 245/40 ZR19 tires
  • 9J x 20 ET 30 using 255/35 ZR20 tires
It seems to me the Tiger Claws you are considering may be too wide, however, it's possible that that offset could offset that discrepancy or make it worse. I'm almost certain it will require spacers. With the greater offset in the Tiger Claws, there is a chance the wheel may rub on the suspension bits. Maybe someone more knowledgeable on the subject could better guide you.
Old Jan 25, 2018 | 12:16 AM
Flipr78's Avatar
Anyone else fitted similarly sized rims with higher offset? Does the higher offset fit the wheel under the car more or push it out more? If I need spacers would 1 inch do the the trick?
Old Jan 25, 2018 | 07:49 AM
Unfortunately I have no experience in the matter, but I would also like to know.
AndrewJR
XE ( X760 )
Apr 27, 2020 08:52 AM
johnfrye
Feb 20, 2014 03:17 AM
jeiiomix
Feb 3, 2010 11:49 PM
Tommy K
Jul 8, 2009 09:08 AM
sempaipaul
May 23, 2007 08:36 PM
