1999 Jaguar XK8 timing chain replacement
Old Jun 9, 2015 | 05:30 PM
bowmanec's Avatar
Default 1999 Jaguar XK8 timing chain replacement
I'm sure it is posted but I can't find it. I'm replacing the timing chains and tensioners in my '99 xk8 v8
4.0 motor. I'm having a difficult time finding the crankshaft alignment hole. Any help is appreciated.
-Craig
Old Jun 18, 2015 | 06:06 PM
andrew lowe's Avatar
it is in the bell housing, rubber bung in a round hole roughly at the centre/ bottom.
Old Jun 19, 2015 | 10:44 AM
-Craig
Craig,
I've moved your question from General Tech Help to XK8/XKR forum. Many members here with the same model have already done this and will be able to help.
Old Jun 20, 2015 | 10:54 PM
stevepaa's Avatar
Do you have JTIS? There is a detailed explanation in there. Best to read it completely and understand the whole process before you start.
Do you have the camshaft lockers? And a big torque wrench?
Old Jun 20, 2015 | 10:58 PM
NBCat's Avatar
DO NOT use the crankshaft holding tool to hold the crankshaft from rotating when attempting to remove the harmonic balancer.
Under no circumstances is the engine to be rotated in an anti clock direction when viewed from the front of the vehicle or damage to the main and rod bearings will result.
Old Jun 23, 2015 | 07:16 AM
bamforp's Avatar
I knew not to use the camshaft locking tools to stop the crank rotating but why is it not a good idea to use the crankshaft locking tool i.e. the large spanner like tool not the pin that fits in the bell housing? I used the crank locking 'spanner' that came with the tools I hired to do my chains and I'm not sure how else I would have managed to loosen the balancer bolt.
Old Jun 23, 2015 | 04:21 PM
johns55's Avatar
I locked the engine via the transmission bell housing (flywheel).
Old Jun 23, 2015 | 04:41 PM
plums's Avatar
In the post you are referring to, I suspect he's got the alignment tool(pin) confused
with the locking spanner.
xjrjag
May 21, 2026 09:05 PM
lobsterD90
Nov 12, 2022 09:51 PM
celticpiping
Sep 18, 2015 06:17 PM
Newsguy
Aug 30, 2015 11:27 AM
souldoubt
Aug 25, 2015 08:15 PM
