1999 Jaguar XK8 timing chain replacement
I'm sure it is posted but I can't find it. I'm replacing the timing chains and tensioners in my '99 xk8 v8
4.0 motor. I'm having a difficult time finding the crankshaft alignment hole. Any help is appreciated.
-Craig
-Craig
I've moved your question from General Tech Help to XK8/XKR forum. Many members here with the same model have already done this and will be able to help.
Do you have JTIS? There is a detailed explanation in there. Best to read it completely and understand the whole process before you start.
Do you have the camshaft lockers? And a big torque wrench?
DO NOT use the crankshaft holding tool to hold the crankshaft from rotating when attempting to remove the harmonic balancer.
Under no circumstances is the engine to be rotated in an anti clock direction when viewed from the front of the vehicle or damage to the main and rod bearings will result.
I knew not to use the camshaft locking tools to stop the crank rotating but why is it not a good idea to use the crankshaft locking tool i.e. the large spanner like tool not the pin that fits in the bell housing? I used the crank locking 'spanner' that came with the tools I hired to do my chains and I'm not sure how else I would have managed to loosen the balancer bolt.
with the locking spanner.
xjrjag
May 21, 2026 09:05 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
Aug 25, 2015 08:15 PM
