1999 XK8 drive cycle
Old Apr 12, 2015 | 07:26 PM
rogercampos007's Avatar
Default 1999 XK8 drive cycle
I can't pass smog. The computer indicates that comprehensive component , catalyst, secondary air system and oxygen sensor -NOT COMPLETE. I was told that I have to do a drive cycle. How is one done on a 1999 XK8?
Old Apr 12, 2015 | 10:39 PM
Johnken's Avatar
Hi Roger, I'm not sure, but someone will recognize it. I bet it is a number of miles that allow the settings to register. Where are you located? That may help folks help you.
Old Apr 13, 2015 | 03:45 AM
test point's Avatar
Here is the 'Drive Cycles' document for an '01 S-type. I am not aware of one being available for the XK8/R but I suspect that it would be similar.
https://www.jaguarforums.com/forum/s...04/#post384039
Old Apr 13, 2015 | 07:47 AM
mrplow58's Avatar
I am having the same problem in Indiana. My scanner is not showing any faults, and I had been driving for two weeks after the last repair to the evap system, and erasing the faults. I have driven a number of times on the highway, and all over town. I have had to buy a temporary plate, to complete the inspection process. Hope I don't have to do it again. I think I might try a different test center too.....Good Luck....Mike
Old Apr 13, 2015 | 07:57 AM
mrplow58's Avatar
I see my problem, or at least part of it. I keep my tank full all the time, or whenever I see that premium prices are lower. I need to get it below 25%, then 15%. My heated oxygen sensors also don't have much swing to them, even though I replaced the upper sensor on the passenger side, because it registered a fault. Hope this works. I have a lot of driving to do, just to get the tank level down....Thanks....Mike
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
kelliott
May 31, 2022 05:26 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
David Thompson
Sep 3, 2015 07:48 PM
