1999 XK8 Fuel Door Actuator
Old Aug 24, 2022 | 03:24 PM
XK8WGM's Avatar
Default 1999 XK8 Fuel Door Actuator
Am I seriously to believe that Jaguar "installed" this part on a $70,000+ car with two-sided tape? No screws, bolts, or brackets? I got a replacement actuator but of course it did not come with the expensive plastic nut that holds it on. I just ordered one of those also. Because I did not want to risk the fuel door being open and someone catching it on the way by, I taped the actuator to the inside of the fender and then, wait for it, wrapped a kitchen twist tie around the neck that protrudes into the fuel door and latches it shut!!! It worked. Now when the actual nut comes, I simply remove the twist tie and install the nut. Hopefully, it is in good used condition and will hold sufficiently.
Old Aug 25, 2022 | 03:03 AM
PKWise's Avatar
Yep, the 2003MY is the same. Use of double Sided Tape - I never noticed that before, I wonder if that has ever failed and someones solenoid fell off?
Old Aug 25, 2022 | 07:00 AM
SamtheSham's Avatar
SuperGlue??
Old Aug 25, 2022 | 08:04 AM
Jon89's Avatar
RTV sealant may be a better option....
vandenplas90
XJ40 ( XJ81 )
Oct 23, 2021 06:48 PM
itswemy
Jun 12, 2020 03:24 AM
drbill
May 16, 2017 07:36 AM
shtse73
Mar 14, 2015 11:40 AM
markrkolb
Dec 6, 2010 01:43 PM
