1999 XK8 Transmission
Old 03-15-2018, 05:51 PM
terry73's Avatar
Default 1999 XK8 Transmission
Ever since my battery was removed and replaced my transmission has acted up. It will bang into drive on occassion, is there any connection to the battery change out that could cause this. Does it need to be programmed?
Old 03-15-2018, 06:14 PM
JagV8's Avatar
Received 4,488 Likes on 3,905 Posts
The most obvious is that an upset engine will upset the trans. So, investigate the engine. Check for codes, check OBD monitors, check sensor data and fuel trims.
Old 03-15-2018, 07:55 PM
RJ237's Avatar
Received 2,786 Likes on 2,229 Posts
There is a connection in that the tcm and ecm will need to reset for a short time after a hard reset or battery replacement. But that should only be for a few restarts.
Banging into drive is often an indication of A drum failure, but not reprogramming requirement.
Old 03-16-2018, 02:28 AM
Mark Oz's Avatar
If its the first drive after a reset, the fuel trims need to relearn what is going on.
There is a drive cycle to do, to do this. I think its in the stickies somewhere.
Someone here may be able to link to it.
I did a battery reset without knowing what the procedure was.
A few short town trips etc. and things still didn't feel right.
Once I did the long highway cruise everything settled down and fuel economy and shifting improved.
You may have to give it a little time to reset and learn again.
XJsc-guy
06-14-2016 12:33 PM
rellsimone
06-30-2014 08:34 PM
Cerberos
07-09-2013 09:29 AM
warrickUK
03-03-2009 12:59 PM
festo
08-13-2008 07:29 AM
Quick Reply: 1999 XK8 Transmission
