1999 XK8 transmission replacement suggestions
Old Jun 27, 2021 | 08:46 PM
DNShade's Avatar
Default 1999 XK8 transmission replacement suggestions
Well it's that time - my 99 XK8 with 165K on it and well it's time for a new transmission. So was just throwing it out here if you guys have any suggestions on good places to look for decent priced used transmissions etc.
Thanks for any help or suggestions!
Old Jun 28, 2021 | 03:24 AM
kansanbrit's Avatar
Get yours rebuilt.
Old Jun 28, 2021 | 12:45 PM
Kuddlesworth's Avatar
In the UK a ZF specialist will charge you about £2600 for a rebuild which is going to be a lot cheaper and better then buying a second hand one. For example Jaguar Gearboxes Archives - Automatic Gearboxes - Gearbox Rebuilding Experts (automatic-gearbox.co.uk)
Old Jun 28, 2021 | 03:08 PM
CA Jag's Avatar
Pro rebuild in Sacramento is 3,400 Jag Heaven (Stockton) is supposed to be a good source of parts. I haven't worked with them. Are you going to DIY?
Old Jun 28, 2021 | 06:45 PM
xalty's Avatar
these transmissions are so commonly rebuilt most chains will be experienced enough to fix them correctly
Old Jun 28, 2021 | 06:55 PM
CA Jag's Avatar
true but it's expensive. maybe hard to get parts for a 20 year old transmission? am sure BobRoy knows the answer to that one
Redeye
Jul 23, 2025 05:15 PM
Todd Wiens
Oct 2, 2021 11:02 AM
viscoussquirrel
Sep 6, 2021 07:45 AM
whitek03
Nov 20, 2016 07:37 PM
Frog
Oct 17, 2011 03:31 AM
