1999 XKR 4.0 - 2002 XJR Brakes
Old Sep 26, 2016 | 02:46 PM
Rob XKR's Avatar
Default 1999 XKR 4.0 - 2002 XJR Brakes
Hi
I am new to the forum, so I am just getting the hang of how to do things.
Let me know if this is the wrong place.
I have a 1999 XKR 4.0 with the standard Jag brakes, and I would like to upgrade them to the larger Brembo type.
I have been offered a set from a 2002 XJR.
I have checked and I think the part numbers for the discs are the same.
Does anyone know if these will fit, maybe with a bit of adjustment.
Robin
Old Sep 28, 2016 | 03:35 AM
jamdmyers's Avatar
Check this link in DIY Sticky
https://www.jaguarforums.com/forum/a...it-2001-xk-pdf
Old Sep 28, 2016 | 06:22 AM
Ungn's Avatar
I'd like to know this too, as XJR's seem much more plentiful in the junkyards.
I think that the Spindle needs to be drilled/tapped to adapt Brembo calipers. The XJ/XK spindles are completely different, so its a feat of good engineering if they share calipers/brackets.
Old Sep 28, 2016 | 02:13 PM
Rob XKR's Avatar
Default XKR/XJR brakes
Hi
I am going to get them anyway, so I'll let you know what happens.
Watch this space....
Old Sep 29, 2016 | 02:47 PM
fmertz's Avatar
There is great information in these threads:
03-xk8-brake-upgrade-question
brembo-conversion
The brake lines remain a bit of mystery, though. Let me know what you find out.
Old Oct 8, 2016 | 11:27 AM
coupeguy's Avatar
I'd be interested in knowing how this works out as well. Been thinking about the same upgrade.
