2000 XK8 Misfire.
i have read in a couple threads that the ABS Module's known problem can cause the "reduced power" message and rough running. can anyone elaborate on that
for me? I'm curious if the random ABS/ASC/TRAC warnings could be the known Module issue and that in turn affecting the ECM........
The ABS module is at one end of the CAN bus, the instrument pack is at the other end. Each has a 120 ohm terminator resistor, which together gives the 60 ohm value the CAN bus needs to work properly. A fault on the ABS module could disrupt the whole CAN bus - whether that is your problem here is anyone's guess. One simple test you can do is measure the resistance of the CAN bus at the OBD port with the ignition off to see if it is close to that 60 ohm value and take it from there.
Dibbit which pin in the OBD port is that? my Chromebook won't play nice with the diagrams here
i have read in a couple threads that the ABS Module's known problem can cause the "reduced power" message and rough running. can anyone elaborate on that for me? I'm curious if the random ABS/ASC/TRAC warnings could be the known Module issue and that in turn affecting the ECM........
But in addition to the cracked solder joints for the pump motor connector, in every Ate ABS module I have opened I have found several starved, cold or cracked solder joints for other components and the large multi-pin connector through which the wheel speed sensor and CAN signals pass. Faults with the CAN typically trigger Network DTCs (U-prefix), so again, you would need a scan tool capable of reading those to see what the computer modules could tell you to aid your diagnosis.
dibbit's advice to measure the resistance on the CAN network is a good idea. You can measure this at the Data Link Connector pins 6 (Yellow wire) and 14 (Green wire).
It would be rare for an ABS problem to cause rough running, but if the CAN is malfunctioning, all bets are off.
Cheers,
Don
Cheers,
Don
Dibbit, i won't be sending the ecm off for a rebuild until I'm sure that the problem. i don't work that way, i like to find the problem 100% and fix it
as for the trims, i don't remember exactly what the readings were but it seems like them and the m.a.f. readings all pointed towards lean running.
i got this car with it already having issues, the P.o. was convinced it was in the fuel system. He has passed so i can't ask him what he had done.
it was stored when i picked it up, but with no fuel in it. so, no old gas. i have a new filter but have not changed it yet. i need to check the pressure.
it does act at times like it's starving for fuel so it may very well be there. sometimes i swear i hear a vacuum leak, but then the next time i start it
i don't. So that maybe an intermittent problem too.
Don, i doubt that it has the enhanced software. i already expected to have to get it.
the seat comes apart and trashes an engine.......
Len Apcar
Oct 8, 2024 10:58 AM
Gblauf
Mar 3, 2013 09:36 AM
